Question about Symbol Motorola MC3090 Handheld Computer
What causes this error: Error Code: WCLaunch WCSAPI Unable to load/initialize
    New Friend:
  • 65 Answers
Its simple you need to reload this to factory defaults, I can guide you or provide instructions how to obtain needed files You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 20, 2009
Good day I have a problem with a terminal symbol MC3090 model which I can not see your IP and the macro is there an application called WCLAUNCH to see these data are not as able to restore it or where to download that program, I hope you can help me solve this problem, thanks.
Posted on Jan 30, 2012
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
Why do I get WCSAPI error only at my workplace?
answers.microsoft.com/.../wcsapi-error.../5d1f5c67-50b6-4e06-8d6f-e30...
See if the above answers your issue.
Jun 30, 2014 | Symbol Technology MC2180 WLAN BT ENGLISH...
MC9090/615. Why can't I connect to wireless network?
Did you initially set it up with a CAT 5 (RJ45) cable plugged in to you PC? If you didn't, you have to use a cable to set it up initially and then the wireless will work properly... this is why they usually provide a CAT 4 cable in the box. Read the instructions carefully. If all else fails, call the mfr;s toll free number for assistance or send them an e-mail under Contact on the support heading.
Apr 14, 2011 | Computers & Internet
Brother MFC-8440 Machine Error Code 7A - tried to print something and machine stopped, beeped and gave me this code. No resolution from Brother other than to have a tech come look at it. Any insight...
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | Brother MFC-8440 All-In-One Laser Printer
Error code f 25 is blinking and the washer will not do any thing'
The F25 error code is indicating that the control is unable to detect the motor speed. Causes of the code could be the motor, loose wire connection, failed motor control board or a failed machine control board.
Jan 18, 2011 | Kenmore HE2 Plus Front Load Washer
UNABLE TO INIT
Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
Jan 06, 2011 | Brother DCP 115C All-In-One InkJet Printer
U2 error code
Hi there, Error U2 -
Possible Causes - Loading
Check loading to ensure no items extend
beyond the height of the drawer.
Good Luck!
neo
Dec 28, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Symbol Motorola MC3090 Handheld Computer Logo
3,730 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
