Question about Canon PowerShot A560 Digital Camera
My camera will not download to my computer. When I connect, the green indicator light is on but nothing will function. On my monitor it states that a high speed port is needed. However, I have used the same port in the past with no problem. Since my last download I installed a CD burner. Could this have something to do with my current problem? Thank You...
    Brigadier General:
  • 11,967 Answers
Use a separate card reader to download your pictures.
Posted on Sep 23, 2009
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
The green light indicating power is blinking on and off and nothing is showing up on the screen.
when the green light is flashing it means it's not getting a signal from the computer..
1. try toggling through available sources with the source button on the monitor.
2.check all cables leading from the pc to the monitor.
Apr 02, 2010 | LG Flatron L1718S LCD Monitor
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Resume light coming on but printer won't work
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Problem with A610 Fuji - pictures wont dowload
Are you sure the computer s 'seeing 'the camera this time. USB can be a bit iffy. Leave the camera plugged in but switched off. Repbbit the computer and switch on camera Check 'My computer' to see in there is a 'New drive' indicated.
Aug 04, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Canon PowerShot A560 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
