Iomega mhd40-u Hi, I have just been given this drive by a friend, I cannot add or delete any files, how do I resolve this?
IB4G2008
  • 3587 Answers
SOURCE: cannot restore data from iomega backup pro
yes..that is quite the case. you may wish to do a restore all approach, perhaps to another drive, if you have that option.
Posted on Feb 11, 2008
  • 24 Answers
SOURCE: I am trying to add more files to my iomega hard
Your external hard drive is formatted NTFS. This is a Microsoft proprietary hard drive format which is why Mac does not have a driver to write to it out of the box. You have two options:
1) You can either make sure to buy Western Digital products which all come formatted FAT32 which is writable by Mac's and PC's (There is a 2GB file limitation, a single file can not be larger than 2GB with FAT32)
2) Install a NTFS driver. The NTFS-3g driver is stable and I have been using it since beginning of 2009 with no problems, you can download it here (http://www.ntfs-3g.org)
Posted on Nov 18, 2009
  • 18 Answers
SOURCE: How to delete files and folders off my IOMEGA 1TB
you can just connect your hard drive to your pc and open the folder from my computer and select the folders that you want to delete and press the delete key in your keyboard. then the computer will ask you that " you want to delete the selected files and folders?" then you press ok. it will deleted
Posted on Sep 14, 2010
  • 4961 Answers
SOURCE: the flash drive won't free up space when i delete files on it
Try reformatting the drive.
Posted on Jul 01, 2012
spruell9
  • 6 Answers
SOURCE: where to obtain the driver for an Iomega 31399100 model MHD40-U DISK DRIVE
I've got an external drive I believe it's the same type of drive. I have 250 Meg disk I can insert so you can just keep on filling up 259 disk. Why I stopped using this external drive us well you can get memory sticks that store terabytes now for the prices 1/10 the cost as one 250 dis. I know what you're wanting is a way to get the pictures back. Mine you just plugged into a USB port on a Windows 7 or above operating system and it found the driver. If your drive is the same type try finding another windows computer and plug the drive into it. I bet it will find and load the driver needed to get your pictures off. Unless and this is a big unless you're disk is corrupted. There are still tech shops that can read disk sector by Sector and pull off you're data for you. It's a little time consuming because it doesn't rely on the drive or computer they literally read the hexadecimal code then print it out for you.
Posted on Nov 04, 2016
Iomega LPHD-UP 500GB power issue?
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly.
I suggest you get a new AC power adapter for this drive.
Apr 13, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
Jan 14, 2012 | Iomega 33914 Storage 160gb Ego Silver...
I work on an iMac and have been using Iomega HDD 500 for backing up, which then became full, so I instructed it to delete oldest files. A day later it has suddenly changed its status to Read only. What...
You can change the permissions on any given folder, drive or volume by clicking it once and selecting "Get Info."
Then, to change the access and/or permissions, in the lower right hand corner of the Get Info window, click the lock icon and enter your password.
Once it's unlocked, change the entry next to your username where it says [yourusername])(me) to Read/Write.
Then, click on the little gear icon and choose 'Apple to Enclosed Items.' It will ask you if you're sure, tell it yes.
If you do not see your username in the list, click the plus icon to add it, then follow the steps above.
Jun 10, 2011 | Iomega (33090) 250 GB Hard Drive
Hi there. I have a 500gb Iomega Prestige external HDD. I was in my external HDD files, moving some photos from one file to another (nothing I haven't done a million times before). When I moved one...
you could run the chkdsk utility
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Jun 07, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
Hi, I have an iomega 320gb external hard drive. My problem is that my computer takes ages to read the drive. And when it does read the drive, it shows the files to have 0bytes of data. I got some kind of...
Possibly you may have some file on the computer that needs deleted. Some of your other problems seem to be part of the normal hi-jacking from going to web sites. Make sure you have a updated Anti Virus, Registry fix, disk cleaner. and necessary software on your computer? You might go through those files that you want to tranfer, and delete out one's you really won't need, and see if that helps. I have a feeling it will if you delete the right one. A real good disk cleaner might do the job.
Dec 21, 2010 | Iomega Computers & Internet
Complete user manual as said to be available in document with product SPHDU2 I need more detail than "drad and drop copies of your critical files onto the drive" I am computer iliterate
Open "My Documents".
Hold the CTRL key down, and click the mouse on the first file/folder that you want to copy.
While holding the CTRL key down, click the mouse on the next file/folder that you want to copy.
While holding the CTRL key down, keep clicking to "add" more files/folders to your "selected" objects.
Release the CTRL key.
Click with the SECOND (usually the RIGHT) mouse-button on one of the selected files/folders.
Point at "Send To".
Click on the icon for your your IOMEGA device.
The selected files/folders will be copied.
When the 'copy' completes, do _NOT_ delete your original files.
Instead, keep those original files in your 'My Documents' folder,
and keep the copy on the IOMEGA. That way, if your C: disk-drive fails,
or if the IOMEGA fails, then you still have _ONE_ copy of your files.
Dec 17, 2010 | Iomega eGo Portable Hard drive 500 GB ...
How to delete files and folders off my IOMEGA 1TB EXTERNAL HARD DRIVE
Sep 14, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Problems adding files onto the hardrive
This sounds as though the Iomega has got locked somehow.
Do a get info on its desktop icon and have a look at the lock checkbox. Also look at the write permissions while you are there.
May 10, 2009 | Iomega (33654) Limited Edition 500 GB USB...
External drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Iomega 33089 250 GB Hard Drive
Cannot restore data from iomega backup pro
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
219 people viewed this question
Alun Cox
David Payne
David Payne
