Question about Garden
Carburetor adjustment on McCulloch Mini-Mac 30
Which way does one turn the idle adjustment and high speed adjustment needles to increase or decease speed/power? The manual does not say.
  • 546 Answers
Turning Hi & Lo mixture screws in leans the mixture,out rich-ens it.turn the T screw in to increase idle speed the chain should slowly come to a stop at idle [chain brake off] adjust Low needle first until it accelerates smoothly then Hi needle for best 'revs'.then Lo again if necessary if you don't know where they were set before,start w/ screws 3/4 to 1 turn out from a lightly seated position
Posted on Sep 23, 2009
Testimonial: "Thanks. That answers my question - presuming "in" means clockwise. "
  • 55 Answers
You got it almost right. The screws go in to lean and out to richen. Idle will be in to increase and out to lower.
Always adjust the high speed needle first. Slowly lean till you hit top rpm then back off 1/8th turn.
Low speed needle, slowly lean till the engine stops burbling on exceleration. If you go too far the engine will stop quickly when the throttle is advanced. Back it off a little and try it again.
Back to the high speed needle, adjust again.
NOW adjust the idle screw.
Time to adjust the needles again.
This procedure may need to be repeated as the engine breaks in. Most small industrial engines need a minimum of 5 gals through the engine to break in.
Posted on Feb 12, 2010
How how to adjust the screws on the carburetor of the yard machine yard cultivator 31 cc
Hi Christi:
This is a "standard approach" that i've used for various small engines for a long time. It may not be factory specs, but it's worked for me.
- First, gently turn both screws in (clockwise) until they just touch the seat. BE GENTLE as you don't want to damage the needle or seat.
- Second, back out both screws 2 turns. This is a "guess" start point.
- Third, start using normal procedure.
- Once the choke can be opened, with the saw at an idle, adjust the slow speed screw until the saw runs at its slowest smooth idle.
- Finally, increase the engine speed and adjust the high speed screw.
Try turning it clockwise.
- If RPM increases, continue until it starts to decrease, then back off 1/4 to 1/2 turn.
- If RPM dropped or engine stalled, back off 1/2 turn and try again.
Hope this helps.
Aug 31, 2015 | Garden
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
What is carburatoradjustment on a modle 358.355140
This is your carb:
http://c.searspartsdirect.com/lis_png/PLDM/00051166-00002.png
Here is the parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358355140/0247/1503220/00051166/00002?blt=06&prst=0&shdMod=358355140
The initial settings are 1.5 turns from just closed.
Adjust the "L" Needle (low) so that the engine does not stall or hesitate when the throttle is increased.
Next run the engine at MAX speed and adjust the "H" Needle until it just barely stops missing and you get MAX speed.
Recheck for stalls or hesitation from idle... Adjust L Screw again if necessary until it no longer hisitates or stalls when throttle is increased.
Recheck MAX speed and adjust as necessary.
Set idle...speed with top screw.
L and H acrews are on the side.
Thanks for choosing FixYa,
Kelly
Sep 14, 2011 | Craftsman Garden
Need to know what the setting is for needle valve on a 460. I increased the gap when I was trying to fix a problem of running too lean. Fix the problem, but messed up the needle valve. The problem was the...
Turn both H and L jet needles CW to stops (lightly), then back out 1-1/2 turns each CCW. This is a basic setting and will be rich. Start the engine and allow to warm up. Pull the throttle full on and turn the H needle CW until the engine starts to speed up, but continues to 4-stroke. Final adjustment is when the engine 4-strokes at speed with no load, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L jet needle CW until the engine idles fairly well, but still allows the engine to 'follow the throttle'. Idle speed screw should be adjusted to keep the engine idling, but the chain should not try to turn. Hope this helps!
Dec 15, 2010 | Husqvarna Chain Saw 20" Bar
The owners manual for my Ryobi 210 describes carburetor adjustment but the photos do not show which screw is the idle mixture adjuster.
The Low speed adjustment screw is the one marked as "L" and would be adjusted during:
1. Idle - to insure running smoothly, and
2. Acceleration - to transition from Idle to High Speed.
The High speed adjustment screw is the one marked as "H" and would be adjusted during:
1. High speed or Wide Open Throttle. Turn about 1/8 either way to gain top RPM's and then back off slightly.
The final screw is an Idle Set screw. This screw sets the actual speed of the Idle and is the screw attached to the end of the throttle cable as it terminates at the carburetor. Turning it:
1. Clockwise - increases RPM's (speeds up motor)
2. Counter Clockwise - reduces RPM's (slows down the motor)
Sep 28, 2010 | Ryobi Garden
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
1984 yz 125 power valve how do i set it
You don't have to do anything It does it on its own as long as the pieces are all there. The power valve is the thing that opens up a larger exhaust hole for the two stroke engine. It is shaped like a spool and it twists as pressure builds due to high rpm. On the 1984 it is on the left side of the bike right up front behind the clutch cover.
Aug 04, 2009 | 2003 Yamaha YZ 125
Throttle adjustment for john deere chain saw
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
Please rate this a fixya
May 11, 2009 | Poulan Pro Chain Saw 46cc 20"
How do I adjustment the carb on an almost brand new weed trimmer?
May 03, 2009 | Poulan Garden
Carburator tune up of charadade 1992 sedan. The engine is running too fast while idle at 1200 r.p.m.
Before you start check the status of your choke. One that is stuck on will cause a high idle. If the choke checks out, proceed to the following:
You should have what's called a 2 needle carburetor. A larger screw adjustment for idle, and a smaller for high speed.
Start by adjusting your low speed (idle) needle until you reach the desired idle. I prefer about 850rpms. Do this with the engine running and adequately warmed so that your adjustments are not thrown off by the automatic choke.
Next slowly open up the high speed needle. As you open it your idle speed will gradually increase. Adust it in 1/8 turn increments, pausing after each adjustment to allow the changes to take affect. Keep opening it until you stop increasing your rpms, then take it back 1/8 of a turn.
Next readjust your idle mixture screw so that your idle is back down to 850rpms.
Apr 29, 2009 | 1992 Daihatsu Charade
Garden Logo
3,804 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
