Question about Wagner Milwaukee Heat Gun
Where can I get replacement heater elements for a model 750?
Can i change wattage on my dimplex fire place model dfb 8842
This model does have 2 elements and it will likely cut the wattage in half if you disconnect one. Not sure how hard it is to get to the heater assembly, but there are terminals on the right side that probably have spade disconnects. If so, remove one marked D or E, and tuck it away and see if it puts out less heat.
Dec 19, 2015 | Dimplex Heating & Cooling
Spa blower motor
I have found a couple of places that appear to have what you are looking for. They are both in the US and priced in dollars which may be good or bad depending where you are.
http://bathpartsplus.com/MAST-300-750-120/60A-N.aspx
http://www.monstermarketplace.com/bathtub-parts/millennium-blower-120v-with-air-heating-element-and-air-switch
Good Luck.
Aug 25, 2014 | Heating & Cooling
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Water Heaters
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
What heating element do I need for a model 71-30s water heater?
Rheem 71V30 series water heaters use generic 4500 watt element from hardware store.
Look at label on side of tank for wattage.
Look for wattage and voltage printed on end of each element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Aug 05, 2012 | Rheem Water Heaters
How do I find the water leak in Emerson insinkerator H770-SS
The use-and-care manual says that the 'product will eventually fail,' and to install a drain catch pan.
The product has stainless steel tank with 3 year warranty. 1-800-558-5700.
The manual does not show parts diagram, element, or anode rod. This indicates that operation is inside a sealed 1-piece unit not meant for repairs.
High clorine content of water, and hard water, and water pressure over 80 psi will adversely affect any tank heater, and shorten lifespan causing probable leak.
Turn off power:
If you can remove cover from H770, then inspect 750 watt element for possible leaking. Then replace with new element of unknown type if element is leaking.
If leaking is coming from the tank itself, then the unit cannot be repaired. This is true for all tank water heaters.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Aug 04, 2012 | Emerson Water Heaters
Heater Element Replacement
Yes I think they do but these may also be unavailable. You could try sourcing 'after market' replacement elements, these are universal fit elements often from the original suppliers and cheaper too. Try searching the web for Russell Hobbs replacement kettle elements.
Oct 14, 2008 | Russell Hobbs Kitchen Appliances - Others
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Quartz heater parts
I have an older presto quartz heater thats needs a thermostat the info on the switch is as follows
INF-120887B 34-191 15AMP 120VAC can anyone help me out? thanks fred
Nov 28, 2007 | Heating & Cooling
Heater Shuts off at 1500 Watts
Could be a bad element if the heater does not run at all at 1500w.
If it runs a little before stopping, things could just be dirty causing the thermal sensor to shut it off. A good cleaning is needed in that case.
Good Luck,
Denis
Oct 09, 2007 | Marvin W.B. 3150 Convector Heater/Fan
Wagner Milwaukee Heat Gun Logo
47 people viewed this question
Top Wagner Tools & Hardware - Others Experts
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
