Question about Logitech Harmony 880 LCD Remote Control
The cradle no longer charges the remote, and the remote is completely dead. I spoke to my supplier, but he is out of state and can't help - he told me to go online and just buy the cradle, but I'm having problems finding the cradle anywhere without buying the entire remote, software, etc.
Hi.
If you are in the US, you can call Logitech's sales line at 1-800-231-7717 to buy a replacement charger.
Posted on Mar 05, 2010
My Harmony One remote will no longer charge. I took the battery out of it and place it in my Harmony 880 and placed it in it charging cradle. It started charging. I know it is not a battery issue. Yes...
This is a common problem for these remotes. Constant handling of the remote results in dirty charging contacts located on the bottom of the remote. Oils and acids from your fingers and hands also dirty the charging contacts. Also the contacts on the charging cradle can become dirty and have been known to not make solid contact. I would recommend cleaning BOTH the charging contacts AND the cradle contacts using a Q-tip and some good quality rubbing alcohol.Be careful to just wet the Q-tip and gently scrub the contacts only. Careful regular maintenance should help you resolve this problem. Also you could check the Logitech website for recommendations on how to clean their equipment.You can also try the rubber band trick!! Which is while placing the remote into the docking cradle, listen for a beep which indicates a solid connection. While still maintaining a solid grip on both charger and remote wrap a rubber band around both devices. This should ensure a good connection while the remote is charging! Good Luck!
Jan 04, 2011 | Logitech Harmony One Advanced Universal...
My one year old Logitech Harmony 890 is not charging the battery. I have replaced the battery and watched it drop from full charge to 1/4 charge about 2 days. I have verified there is 8.5V at the pins in...
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together. Good Luck!!
Feb 26, 2010 | Logitech Harmony 890 LCD Remote Control
Battery will not recharge. Completely dead. Do I
Are you sure it's the battery and not the charging cradle? Make sure you try some of the following before you buy another battery. If it ends up you do need another one, you can pick up an OEM battery on Ebay for around $10. Just be careful that you get a battery that will charge in the cradle. There are some knockoffs from China that will ONLY charge using a special wall charger, so read the ads carefully.
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
Feb 12, 2010 | Logitech Harmony 890 LCD Remote Control
I have a 880 per the box and it will not charge all the way.
I'm not sure I understand your question completely, but if you are having a charging problem, read the following. You may find something helpful
Feb 05, 2010 | Logitech Harmony 890 LCD Remote Control
I have a harmony 880 remote. Won't charge now.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
Dec 11, 2009 | Logitech Harmony 880 Universal Remote...
My harmony 880 will not charge
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
Dec 02, 2009 | Logitech Harmony 880 LCD Remote Control
Dead. When I put on charger I get no response
Dec 01, 2009 | Logitech Harmony 880 LCD Remote Control
I have a Logitech Harmony remote. It won't take a
Oct 03, 2009 | Logitech Harmony 880 LCD Remote Control
My remote wont charge and it goes in and out of a blank screen. how do i fix it?
Logitech admits that there are problems with charging on some older 890 remotes. I had a few clients with the same issue and got the units replaced. If you can apply pressure to the remote when in the charging cradle and get the screeen saver to come on, then you're a candidate for replacement as a solution. Not the best news, but the truth. Call tech support at 646-454-3200 to discuss the trouble and request a case number.
Aug 10, 2009 | Logitech Harmony 890 LCD Remote Control
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
Logitech Harmony 880 LCD Remote Control Logo
71 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
