Question about U-Line 15R Compact Refrigerator
My chefmate mini fridge is freezing all my drinks
The dial is set to 1 but still everything is freezing. there is this "long tube" that is attached form the top but not sure if that should be up against the freezer section or if this has anything to do with temp regulation. Thanks for any help
  • 9 Answers
SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Posted on Dec 08, 2008
  • 358 Answers
SOURCE: my mini fridge freezes everything
Need to replace the termostat.
Posted on Apr 03, 2009
  • 286 Answers
SOURCE: chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Posted on Jul 22, 2009
SOURCE: where does the little tube
Where does the little tube on the freezer go? Where do I snap it back in at?
Posted on Aug 08, 2010
  • 4 Answers
SOURCE: Sunbeam Slush Magic. We place
the ice is not meant to mix with the drink. (its got rock salt in it ) deeerrrrr
Posted on Jan 02, 2011
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
I have amagic chef 4.4 cu ft mini fridge. when I turn it on, no matter what I set dial to it freezes everything inside. How do I fix this ?
Hi.
This is a classic example of a faulty thermostat.
If it has a electronic controll system the temp sensor is defective.
Oct 28, 2015 | Refrigerators
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
I have a Chefmate BC-87/H mini fridge and I lost my Manual and I need to know if #1 is coolest or #9
jeeze! none of these idots who replied are reading your question!!! I have the same issue not sure which is warmer and which is colder. in my full size fridge, 1 is warmer, and the higher numbers are colder. if you found the solution though- i would really appreciate it if you could let me know! my email is mike41062@gmail.com... i have been searching for the user manual online and cant find it anywhere. cant even find a website for chefmate!!!
Sep 21, 2010 | Refrigerators
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
My chefmate RS 06DR is freezing everything
temp should be38-40 degree F the tub is for ice maker
Aug 14, 2009 | U-Line 15R Compact Refrigerator
I need to find the manual to the Chefmate mini fridge BC-87/H
Hi, get me a model # and I can look this up for you and try ans assist you.
Thanks
Vic
May 17, 2009 | Refrigerators
My mini fridge freezes everything
Apr 03, 2009 | Refrigerators
U-Line 15R Compact Refrigerator Logo
229 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
