It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
You should rule out nasty stuff first.
MBAM !
for a free one its pretty darned good !
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
May I suggest you download "hijackthis"
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Testimonial: "Plenty of advise and options, will make a start on these."
Your target disk I,e your hard drive is full to capcity and need to free up space is what this is telling you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "I have 51.3gb on my hard drive, of which free space is 9.73gb. I'm not sure why this is not enough. "
Reinatall you scanning software as there might b something corupt then because it just does not say your out of space for nothing , check your hard drive and your save point as well if its saving to your hard disk as it should make sure you run scan disk on it. When in doubt reinstall the program if it keeps doing it have the hard disk evaluated.
SOURCE: Have used toolbox 5.0 regularly to scan film negs
Either your hard drive is full, or the program is trying to save to a different drive (CD, flash drive) which doesn't have room for files.
If you're saving as TIF files you may have filled a lot of hard drive space, as they are much bigger than JPG files.
" I have 51.3gb on my hard drive, of which free space is 9.73gb. I'm not sure why this is not enough. "
