Question about Powerware PW9150 12.5KVA/8.75KW (pf1221114ue0010) UPS System
Ups drops load at unpredictable times. battery is good
    Novelist:
  • 169 Answers
If the load is dropped then there is a serious fault with the ups, even if the inverter fails, it should go to bypass and not drop the load.
Sound like a control fault, I suggest you need a ups tech.
This equipment has many dangerous parts inside. Batteries are always live and very dangerous. The boards are stuffed the surface mount components.
You need an approved service agent, who should be able to help
Posted on Sep 24, 2009
I have a 2007 madza3 2.0 battery is good but when you turn the key it just clicks
Clicking sound is the solenoid activated starting switch pulling in, then dropping out because of low voltage when the starter motor is connected electrically. When the contact drops out, the load on battery is reduced, voltage rises again enough to pull the solenoid switch back in and click. This happens four or five times a second and thus hear the "clicking" sound.
Only a load tester will indicate if battery is weak. Simple voltage testers only show open circuit voltage.
Load testers usually apply a 50 Amp load for 30 seconds. That 30 second voltage must then be compared to the battery's CCA rating, which gives you an true indication of battery's condition.
I suspect a load test will show the present battery to be weak or bad. If battery is five or more years old, it owes you nothing.
Best deals on new batteries is WalMart with free installation.
Sep 22, 2017 | Cars & Trucks
I put a new starter on a year ago. today put on anew alternator and my truck will only turn over a few times quit
Battery ? battery cables ? Test the starting system , voltage drop starting system ! go on you tube a check out voltage drop testing starting system .
Jan 09, 2016 | Cars & Trucks
I have a 1995 poniac bonneville and every time i press the brakes the gauges drop. Battery is good. Alternator good. Lights dim and some time kills my car
the brake lights will not kill a car or dim lights so there is a massive short in the system or the battery is not as good as stated
check for battery terminals ( posts and terminals) are shiny clean and tight including the ground wire for the battery
have the battery load tested ( not voltage tested )
check the alternator output ( auto electrician ) check the drive belt is in good condition and tight
Oct 21, 2015 | Cars & Trucks
Where is the problem with "-DC bus low" EX11RT?
How are you checking the batteries? If you are simply reading the voltage with a multimeter, then this is probably your issue. The batteries, when getting worn out, will often show full voltage in a static (non-loaded) state, but as soon as they are called on to produce load, their voltage will drop significantly, thus giving the DC bus low indication. Batteries in UPS's are similar to car batteries, they need to be tested under load to ensure they are good. If they are three years old or older, chances are they need to be replaced.
Jun 18, 2015 | Computers & Internet
CHARGER NOT SHOWING ANY KIND OF INDICATION THAT UNIT IS ON OR NOT
You need to insert two healthy cells (together on either side) before the indicator will illuminate.
If it doesn't, then the charger might be faulty.
Open circuit cells will also cause the same symptom, although it's very unlikely that you willl get more than one out of four failing. Dropping a cell can cause unpredictable results.
Mar 27, 2011 | Quantaray Rapid Battery Charger with 4...
Battery on full charge then start truck drive to town and noticed volt gauge at low turned lights and access off got home shut truck off tried starting after shut down and noting but dead bat havn prob...
You need to fully charge the battery and load test it, then check the charging system and alternator drive belt for tightness. do not remove cable when running or it can harm the charging system...ok on older cars, no longer good practice. Quick check of charge system can be done with volt meter across the battery. Volts should read between 13 and 14volts and not drop over time. With all lights, heater etc on volts should be better than 12.5 (usually above 13 and again, not drop with time.
Oct 26, 2010 | Ford F-250 Cars & Trucks
THe remote key on my jeep works 60% of the time
unfortunately this is rather unpredictable. for the low cost of a battery, i would try that. if the key still is unreliable, then you know what your next step is... good luck!
May 28, 2010 | 2005 Jeep Grand Cherokee
Why would batteries recharge in an unpredictable manner? Sometimes they are fully recharged and the next time the show they are recharded but they are ot.
This normally happens when the Power IC of you phone is blown. Due to which the battery is not able to hold the charge. Even if you purchase a new battery it will give you the same problem. You can get the phone repaired by changing the power IC.
This issue occurs when the phone is dropped onto a hard surface.
Hope this information is helpful to you. Please do not forget to rate this solution.
Thank you for choosing Fixya
Nov 11, 2009 | Audiovox Bosch 718 World Cellular Phone
Jornada 720 touchscreen calibration doesn't last
I had the same problem, and i fixed, it's not totally true, the inners electronics components suffer damage with time, i think the hings and flex suffer needs to be cleaned with time, I follow the instructions at http://www.hpcfactor.com/support/cesd/h/0046.asp with to much care, an voila no more recallibrations needed,
Feb 27, 2009 | HP Jornada 720 Pocket PC
1999 VW beetle won't start; battery good
the "brain" of the car might be giving out. one thing about the brain is it controls everything...mainly the cpu thats gives out codes!
Jul 29, 2008 | 1999 Volkswagen Beetle
Powerware PW9150 12.5KVA/8.75KW (pf1221114ue0010) UPS System Logo
70 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
