Question about Karcher Garden
I have a model 5000g. it might have 15 hrs. total running time on it. when i tried to use it last it would not build pressure. i took the pump apart and cleaned and regreased it. everything looked good. ive got good pressure to the pump but just a small spray out the wand. when running there is no real load on the engine. it has always been kept inside in a warm enviorment.
  • 33 Answers
SOURCE: pump on my pressure washer will not pressuerize
there is a loader and unloader valve on your pump bolted to it. if it frozen in the open position it will never build press. most of the time this is caused by leaving cleaning solutions in system after use and let set up for a long period. it causes the aluminum case to corrode.;you will have to dissassemble and clean if not to bad. if not your going to have to replace.
Posted on Apr 21, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
  • 92 Answers
SOURCE: Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
Posted on Jul 22, 2009
  • 384 Answers
SOURCE: I have a Generac pressure washer, model #01450-0,
Take a small diameter wire and poke thru the discharge hole of the spray head to clean out.
Second time in 6 months that I had the same problem. The problem is alway in the spray head.
Posted on Jul 24, 2009
Biggdex35
  • 333 Answers
SOURCE: Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
Posted on May 24, 2010
Sprayer looses pressure pump issue ?
You can take the intake part of the pump apart and clean/lube the diaphragm of the pump. If you didn't clean it out last time it was used there will be residual or cake built up. Make sure the down snorkel is clear and doesn't have any contamination in the tube. Check the screen/filter also.
Jul 03, 2014 | Fimco 25 Gallon Trailer Sprayer with a 12...
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Water leaks from the door of countertop model on
My older model had cheap plastic type rivets around the window. Of course they broke and water leaked out the window. I took the door apart and put in a new gasket the siliconed the heck out of it!
Put dishwasher on a counter or floor and put a nice thick phonebook under neath the opened door for support. Carefully replace window with gasket and a bead of silicone. Put enough weight on top to press it down and seal it. Leave for 24-48 hrs. I've replaced the window 3 times and this fix has lasted 2 years now. total cost about $10 and a little effort. make sure you use heat tolerant silicone.
Dec 22, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
1984 GM 7oo R4 automatic trans. looses power while setting
MAKE SURE TRANSMISSION FLUID LEVEL IS CORRECT. BUT THE TRANSMISSION OIL PUMP IS TOO WEAK.IT NOT BUILDING UP ENOUGH PRESSURE FOR THE FORWARD CLUTCH PISTON TO APPLY.ALSO YOUR FORWARD CLUTCH PISTON SEALS.COULD BE LEAKING.WHEN ENGINE GET WARM AND THE TRANSMISSION FLUID GET WARM.IT CAUSES FORWARD PISTON SEALS.TO EXPAND ENOUGH TO BUILD UP PRESSURE SO THE FORWARD CLUTCH PLATES WILL WORK.LOOK LIKE YOU ARE GOING TO NEED A TRANSMISSION OVER HAUL.
Aug 30, 2009 | 1984 GMC S-15 Jimmy
Parked the car last night wouldnt start in morning have fuel at fuel rail can hear fuel pump locked and unlocked couple times with key and key fob.Disconnected battery 3 times 15 minutes each still...
Maybe a security passlock problem or ignition control module.Could still be a fuel pump issue.pump may run but not be building pressure!
May 09, 2009 | 2003 Saturn VUE
Jeep runs for twenty minute and stall.
Hello now that I see this messages you making me to remember when this use to happen to me I was totally mad especially that I try everything even on my wedding Honey moon it was a disaster I took my truck to my Honey moon it was 12 hrs from home but it took me around 20 hrs once I get back home from my trip I decide to spend a full day trying to find out what was wrong with my truck I had a dodge ram 1500 1995 5.9 engine and the main problem was with the fuel pump it run fine for about 3 hrs and then it die and I had to wait around 20 minutes and then run another 2-3 hrs in low speed the higher the speed the less time it took to fail again how I found it was the pump well inside in the engine compartment there is a fuel line with a valve to check the fuel pump pressure I did run my truck hard until the fail occur then I install the pressure gauge try to turn the switch on and it was no pressure at the line problem solve the fuel pump was getting hot after couple of hrs running sometimes it only took about an hour to fail try this and see if you have the same problem it could be a different problem but it is good to know this
Apr 15, 2009 | 1994 Jeep Grand Cherokee
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
