Question about JVC AV-27230 27" TV
Dark picture hi please help me if possible i have a jvc 26" tv 14 months old. the picture has virtually gone it is very dark as if the brightness has been turned down, but even the menu bar is the same so cant even see controlls happened instantely when watching a dvd, whiich was on pause then when turned back on this was what happened. any advice would be app. many thanks marcia
  • 1 more comment
  • Hillrod Dec 22, 2007
    Dark picture. Same problem as Marcie123, at about the same age. Evidently just stuck with it. I'm not bad with repairs, though, and I'm willing to try if it doesn't cost too much and I can get some specifics. Thanks.
  • Anonymous Feb 03, 2008
    my tv is so dark regardles pf the setting on standard, dynamic, or sports, I have used the menu to turn up the brightness and everything but tv works well with good picture if only it could be lightened up. I really would like to save this set but it is so impossible to see at all until the room is dark and it still is not light enough.
  • natalie_r_j Jan 25, 2009
    Have a JVC tv AV-32R370KE. It wont exit the menu. even when i press the tv button on remote the menu window remains. Switch on tv and its blank. have to go thru a load of things to get picture but menu is still there!
    Problem Solver:
  • 3 Answers
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Posted on May 15, 2008
  • 281 Answers
Your problem could be the secondary anode cable or CRT socket, and you cannot fix this problem yourself unless you are a techie. It happens when your CRT base socket burns out, or when the pins are rusted or when the spark gap conducts to drain out the secondary anode voltage to the ground. It is better you call a service engineer.
Posted on Dec 20, 2007
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
Mar 21, 2009 | Televison & Video
JVC AV27430 picture seems to have lost the red color
Hi, good day.
Pls check for loose contacts along the crt circuit and likewise, the possibility of a defective crt socket
Feb 15, 2009 | JVC AV-27430 27" TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Jan 24, 2008 | Televison & Video
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
JVC AV27320 Screen too dark
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Oct 12, 2006 | JVC AV-27230 27" TV
JVC AV-27230 27" TV Logo
177 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
