Question about HP Pavilion dv9000z Notebook
I have a DV9000 17" Notebook, power led blink three times
If I plug the power cord to machine without the battery this no power led is on, but if I insert the battery power led turns on, after this I tried to strat the machine and power ligth blinks thrice and no boot.
please help.
  • HP Master
  • 3,866 Answers
Okay the logistics here of this laptop that would be normal for the power light not to come on without battery in place REASON? Because this laptops primary source is battery secounary source AC power.
A Blinking light and no boot means a hardware failure. I would need to personally look at it to tell you 100 percent what is the cause but I would rather you take it to Best Buy and have them do a full eval on it for under $50 bucks if there is something really wroung they can follow up with a warranty claim.
Posted on Sep 23, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
Toshiba M35 S359
This code sound like a power supply or battery depleted code.
Your Power adapter may not be charging the battery. The battery made have reached "end of life".
Mar 28, 2010 | Toshiba Satellite M35-S359 Notebook
Lenovo z60m power "LED" goes off and doesn't charge battery
try draining the battery first.in order to do this. batery should be taken out the laptop. power adapter is unplugged. press and hold the power button then counte 1 to 10 then release your finger after 10 secs. then press in again then count. do that for 3 times. plugged everything back in and monitor the status afterwards
Mar 21, 2010 | Lenovo ThinkPad Z60m Notebook
No power
Try using the laptop with only the power adapter (i.e. WITHOUT the battery).
If the result's the same, you either have a faulty power adapter or a faulty motherboard, sorry!
Mar 13, 2010 | HP Pavilion DV1010 Notebook
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 06, 2010 | Gateway MP6954 Notebook
BLINKING POWER LIGHT
HOW MANY TIMES DOE IT BLINK
BLINK: SHORT-LONG-BOTH-MIX
EXAMPLE: 1 LONG BLINK AND 1 FAST BLINK IS A VEDIO AND MY ALSO BE A BOIS ERROR TOO.
THE LONG LIGHT MAY MEAN A POWER ISSUES, FAULTY WIRE, FUALITY POWER SUPPLY, INTERMITTING POWER SIGNAL TO THE COMPUTER SYSTEM
3-1-2- HARD DRIVE DMA ERROR
ROD
Feb 02, 2009 | HP Pavilion a705w PC Desktop
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Both leds on fron of notebook blink on and off
Sounds like your battery has gone south. See what it does without the battery, just AC.
Jun 06, 2008 | Compaq Armada E500 Notebook
HP Pavilion dv9000z Notebook Logo
913 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
