Question about ASUS P4V8X-X Motherboard
NO BIP,NO POWER,LED POWER IS ON. - ASUS P4V8X-X Motherboard
    Problem Solver:
  • 11 Answers
Motherboard power circut is need to fix. check for warranrty
Posted on Sep 24, 2009
It does bip bip all the time and the led light moves up and down
UNplug it and see if the thing resets it's self. Or leave it unpluged for a while and see what that does.
Dec 26, 2012 | Dehumidifiers
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
My Prolem .DDL 9000a Err-71 & Err-007 I went Solutions
hello there
first please tell me the model of control box? is that error appear emmdiatlty when turn power ON? please email me at ( aabozid@hotmail.com ) i will try to do the best to resolve this problem.
best regards
ashraf abozid
Oct 20, 2011 | Juki DDL-8700
When I try to switch it on you can hear the processor go on but nothing happens, the screen stays black and then a very loud bip.....bip...bip occurs; and then..nothing else
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 20, 2010 | HP Compaq Presario V2000 Notebook
Ok.. MY PROBLEM IS THAT I TURN ON MY PS3 AND IT MAKES THE SOUND BIP..THEN WITH NO VIDEO ON THE TV OR SOUNFD COMING ITS DOES 2 BIPS AND IT TURN OFF AGAIN,,I HAVE TRY TO LEAVE IT ON A COUPLE OF...
lets try a few things bronx,
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode.
then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
Good Luck!
Ruben
Jul 19, 2009 | Sony Playstation 3 (PS3) Console
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
My Acer aspire 5500 don't power on, it bip continously after centrino logo display
If it is making beeps during the startup (called post for Power On Self Test) this is usually a memory error. You can try reseating the memory chips.
Apr 13, 2009 | Acer Aspire 5500 5570-4421 Laptop
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
Power on
Hi
You need to open up the camera again and check all the connections for the cables and make sure everything is connected properly. Most likely it's just a cable that isn't plugged in properly.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
May 30, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
ASUS P4V8X-X Motherboard Logo
110 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
