ViewSonic VA720  17 in. Flat Panel LCD Monitor
Problem for ViewSonic VA720 (Metallic Black) 17 in. Flat Panel LCD...
It won't stay on. It blinks on, then the screen
By brieisfabulo on Sep 23, 2009
it won't stay on. It blinks on, then the screen turns off but it says its still on. So I turn it off, then turn it on again, and it does this exact same thing. It does this for a really long until finally it just stays on. What do i do?
Best Solution
posted on Sep 24, 2009
Very Helpful)
buddymc
Rank: Guru  Computer Hardware  Expert
Rating: 94%, 309 votes
Your power supply is having a problem starting up. This is a common problem on LCD monitors after 2-3 years of use. The heat build up in the case causes parts in the power supply called capacitors to blow out and short out the unit. If you can solder then you should be able to fix it yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm and look at the pictures of what the caps look like when they blow out. Open the back of your monitor and replace all of the ones that look like the pictures and you should be back with a working monitor. The values you need to purchase will be marked on the sides of the blown caps that you take out. Be sure to get low ESR and high temp 105c replacements or you will be back doing the repair again in a month or two. The capacitors from Radio Shack will not work.. The replacements can be ordered from several places on the internet or we can supply them for you. When you install the replacements be sure to insert them with the polarity stripe on the side going the same direction as the old ones when going. If you don't want to do the repair yourself we do offer a repair service for $30 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for ViewSonic VA720 17 in. Flat
Questions and Unsolved Problems for ViewSonic VA720 17 in. Flat
Do you recommend ViewSonic VA720 (Metallic Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
constant blinking of osd lock and other menu options.besides contrast and brightnessgets adjusted on... (More)
Answer
Monitor stays dark when computer turned on and green light flashes next to power button.
Answer
VA720 display goes black after displaying output of computer for 2-seconds.
Answer
replace a 15pin connector one of the pins is broken
Answer
When i refresh my computer the desktop turns black for sec's and again comes to normal. When i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ViewSonic VA720 17 in. Flat...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
