Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
    Problem Solver:
  • 8 Answers
Assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Posted on Feb 03, 2010
No lights on AC unit but fan is running.
Possible that the processor has failed and it seems to give a through circuit to the fan which runs when power is switched on.
You can check the voltage on the processor IC and if absent then you must check the DC voltage on the circuit board. If there is no power then it is the failure of the power supply section and if not the processor is the suspect.
Sep 27, 2013 | Fedders Heating & Cooling
Lost power to ac/heat control.
prob. a bad a/c control head
Jun 15, 2012 | 1993 Chevrolet Suburban
2000 Buick Regal
Check plug in on ignition switch,and if it is good ,replace the switch.
Aug 07, 2009 | 2001 Buick Regal
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
Console does not light up after plugging unit in
Check the power cord for rips of loosness where it enters the unit. if the power cored is fine, this will usually be the result of a power supply board failure. you should replace the power board in this case. the original board is unable to process the AC current at this time.
May 28, 2009 | Fedders A7DH45B2A Dehumidifier
Window AC unit
See if your motor is okay 1st. Find your wires feeding your Fan motor. (This means the 2 power wires L1 & L2 if 220v or L1 & N if 115V) Carefully put the power to these 2 wires and see if you hear the motor hum or start. If it hums the run capacitor could be bad.Try spinning the motor with the power applied. If it starts most likely the run capacitor is out. If it starts without you helping it the control board or switch is most likely out.
It is possible the unit has a energy saving setting. If it gets locked into this the fan may not run.
If the unit has electronic controls and an electronic display read out, the board is the most likely suspect. Unplug it and see if it resets.
If not then the board is probably out with a stuck relay or stuck program. New board time. Or replace the unit.
If it has a rotary or push button type control then either of these 2 switches are suspect.
Jul 12, 2008 | Fedders AEQ07FBG Air Conditioner
Electrical problem
It turned out that disconnecting the battery and reconnecting it reset the control module and fixed the problem.
Jun 12, 2008 | 2001 Dodge Dakota
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
141 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
