Question about HP OfficeJet 6110 All-In-One InkJet Printer
My 6110 says "remove and check cartridge" and no matter what we do - the message remains
  • 82 Answers
Remove the ink cartridge clean it using rubbing alcohol or a clean microfibre cloth and put it back
good luck
Posted on Sep 23, 2009
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant print and im getting an error message
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Sep 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error appears
These messages indicate that the cartridge is not making proper electrical contact, is defective, or is not the correct cartridge. Complete the following steps to diagnose and correct the problem:
Apr 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
For "Guest" who posted on October 30th; try clicking on the following link and going through the troubleshooting suggestions on the HP.com web page:
Cartridge Alignment Troubleshooting
As far as replacing a cartridge and getting a "remove and check" error message, there is more to it (at least sometimes) than having the correct cartridge. If it isn't inserted just right, the electrical contacts between the cartridge and the print carriage will not be complete, resulting in an error.
Also, if there is some ink or other matter on the contacts of either the cartridge or the print carriage, you can get the same result.
Try gently removing the cartridge and putting it back in, making sure that you've got a good contact and the latch that holds the cartridge in is correctly engaged. If that doesn't work, click on the link I posted above and follow Step three: "Perform a ink cartridge cleaning procedure". See if that helps.
Quick question for "Guest" who posted on October 31st; you are using an HP 15 cartridge? I own a 6110 all-in-one and use 56 and 57 cartridges. The product doesn't call for a HP 15. Do you have a 6110v or 6110ix?
Post back your results. Good luck.
Oct 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 all in one
Probably one of two causes:
1)Cartidge is Faulty/Out of Date/Not original.
2)Printer is Faulty.
Most HP cartridges have a specific life, no matter if you use it or not. You should check the cartridge life - its printed on the cartridge itself. If its in date and broken you can get a free replacement from HP. Try a new cartridge first.
If you are still getting an error message after changing the cartridge and your printer is no longer in warranty, its normally cheaper to throw it away than get it fixed. If its in warranty, call HP. They normally replace very quickly.
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer problem
hi,
have you tries inserting new set of ink cartridge???
try this...
> unplug the power chord.
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
agnel
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
