Question about Streamline Frog Jumbo Alarm Clock by
It didn't come with instructions and only one of the "alarm" hands move.....is there something I ma missing. And it has new batteries in them (i bought 2) and they don't move with the time....???
  • 33 Answers
I would bring back to supplier and demand a new one
Posted on Sep 29, 2009
Trailblazer won't start
Open the door,when alarm goes off insert key into ignition and alarm should go off and it should start,try that.
Jul 16, 2017 | Cars & Trucks
If i install new cd player and disconnect neg terminal on battery will this permanently engage killswitch?
A '94 didn't have a stock alarm system that would engage the killswitch. If you/previous owner installed an alarm you should verify how to reset it b4 disconnecting battery.
Td
Oct 24, 2012 | 1994 Toyota Corolla
How to change battery on pontiac solstice
Look at the owner's manual to find the location of the battery for routine checks. Buy a new battery first of the proper size and capacity to have it handy. Remove all the plastic bits you need to to get to the battery and remember where they go! Have a set of box end wrenches to remove the battery terminal cables and the battery hold down at the bottom, then slide the old battery out. Slide the new battery in and connect the cables... positive terminal first. (Do not be alarmed if the battery cable sparks once when connecting any cable, just don't jump and panic and touch something. ) BE CAREFUL NOT TO TOUCH THE TOOL OR YOUR HANDS AGAINST ANOTHER METAL SURFACE WHEN TAKING LOOSE THE TERMINALS as the current will flow from the tool through your hands to ground... you'll get a shock. Do not touch the terminals which your hands when moving any automotive battery. Wear proper shoes too! Do not open battery cell caps to check for corrosion or acid leaks out of curiosity (battery acid can blind you)... if you already have a new battery; turn the old one in for recycling credit usually $5.
Aug 27, 2012 | 2006 Pontiac Solstice
Alarm won't shut off
This system does not have an alarm. The accessory alarm is something else. Check it's sensor and make sure it didn't get knocked into the pit.
Jun 30, 2012 | Simer A5500 - A5500 - Super...
I recently replace the battery in my 2005 Ford Mustang GT. After I installed the new battery the green light for my dealer installed alarm keeps flashing even when I am driving the car. I went to the...
                Hi
                Before Battery Change
                • When was/or when did you notice alarm green light illuminated?
                • When after alarm was disarmed, did green light shine?
                First thing to check would be electrical connections starting from the battery.
                1. Follow positive wire lead from battery to fuse box connections. (Should be along driver side frame rail, or near battery.)
                2. Follow wrie harness to Relay Center. (Find Alarm Relay/Fuse)
                3. Also to Power Distribution Center. (upper driver corner engine bay)
                Relay Switch and Fuse to Alarm should be okay, given the alarm green light illumination.
                The Cars Brain, ECM Engine Control Module, manages messeges between power BattV and Alarm, also other modules and various sensors throughout the vehicle.
                When Battery Supply was disconnected, something happened, that stunned the memory in the ECM.
                Yes, the alarm does need resetting, its actually the memory messages saved in ECM need to be Refreshed.
                (saying "alarm needs resetting") sounds like alarm is broken, when that is not the case. Similar scenario is, when smart phone screen webpage freezes(alarm memory info in ECU). No buttons work, not even power button (Key Fob control). Only way to gain access is to remove battery.
                Lets try an experiment, this will be to loose still/saved frozen information, stuck in computer memory.
                How to Reset Vehicle Computer.
                1. Remove Neggative Post connection.
                2. Remove Positive Post connection.
                3. Let vehicle sit over Two Minutes, this time allows capacitors in vehicle Modules (ECM/PCM, TCM), to release any/all stored voltage, also any voltage in Vehicles ground circuit will be released.
                  • (I would typically wait 15 minutes) Capacitors with out constant Voltage input, will disipate rather quickly, depending on capacity size.
                4. With Battery Still Disconnected. Open Driver Car door, and turn Ignition to RUN Position.
                5. Reconnect Positive Post.
                6. Reconnect Negative Post.
                  • IGNITION is in RUN Position, when reconnecting Battery. Driver Door Is Open.
                  7. Turn Ignition to Off.
                  • Notice if alarm green light is illuminated.
                  8. Hit LOCK Button On Driver Door Switch to Reinitialize Alarm.
                  • Be SURE Key Fob not locked in car.
Mar 26, 2017 | 2005 Ford Mustang
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
I've lost the owner's instructions and need directions for setting the alarm.
  • Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
  • 2 Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
  • 3 Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
  • 4 Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
  • Aug 20, 2010 | Pulsar PXH225 Watch
    Help needd to find out how ro set Alarm on my Bulova Millennia 98A48. A users guide would be appreciated. I have lost mine.
    Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
    I have a spare set of instructions if required.
    Aug 07, 2010 | Bulova Millennia With Vibra-Alarm 98A48...
    Bike won't start
    change the battery in the round black alarm thing a ma jig
    Apr 28, 2010 | 2006 Harley Davidson FXDBI Street Bob
    Streamline Frog Jumbo Alarm Clock by Logo
    120 people viewed this question
    Top Streamline Toys Experts
    ray gallant
    Are you a Streamline Toy Expert? Answer questions, earn points and help others
