Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Weird Noise We have had our hotpoint side by side model hsm25gfrtsa for 3 yrs and it has always made a weird noise some times for hrs and loud enought you have to turn up the tv. I called the place were we purchased it from and they said its out of warrenty, this was less then a year after purchase. Any one know what this is and if there is a recall or how to contact hotpoint direct. I won't deal this this local person again. Thanks
  • DarkStar2 May 11, 2010
    There are many different noises a refrigerator can make, some are normal (boiling sounds, hissing / sizzling / gurgling, whooshing, etc) and compressor humming noise. You could please describe the noise as much as possible ? Has it done so since the beginning of your purchase ? Is your icemaker functional ?
    Genius:
  • 1,036 Answers
The weird noise will be something mechanical.
It will be either -
The Compressor (black "motor" at the rear)
The Control solenoid - Small electrical block with several pipes going through it
The frost-free fan - back of Freezer unit.
If it is the fan, it can be an easy fix if it is knocking something - just remove cover panel.
If it is the solenoid, it may require a rectifer component to prevent buzzing.
If it is the compressor, turn off unit, give it a reasonable knock to wobble it, waitm then re-connect. Sometimes the internal assembly sits in the wrong position.
If it is the compressor that is buzzing, it needs a new run capacitor fitting. If you are competent at soldering, it is possible to identify and replace this part yourself.
Posted on Sep 23, 2009
How to fix speaker in Sylvania projection clock radio SA 85018 2
if it is too loud it will make static and make a weird noise in the speaker my arlarm clock(very old) does that but when i turn it down it stops the static and the noise.
May 03, 2016 | Sylvania Audio Players & Recorders
Grinder make a weird sound
Describe the weird sound. If it is very loud clacking like a machine gun type noise then vacuum our the hopper over the grinder and inspect for a stone jammed in there. The stones always look brown like a coffee bean, it is very common.
May 30, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
My focus has weird noise on breaking loud
On of two things, either your brakes are bad and need to be replaced, you should also have your rotors checked to make sure that they are not warped. Or your wheel bearings are bad and need to be replaced
May 17, 2010 | 2000 Ford Focus
When i accelerate, I hear a weird noise that is
Could be CV joints or wheel bearings. Need to have them checked it could be dangerous.
Apr 07, 2010 | 2000 Acura Integra
Power and lamp lights flashing red and timer flashing green
Hi,normally when the 3 led lights show up they indicate its time to replace the lamp.The lamp that is inside your tv normally last around 3000 hrs 1-2 yrs .Pay attention to any weird sounds which could indicate another problem.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Weird Noise
Sounds like a wheel bearing.You need a mechanic with a lift and some heavy tools. It's not a big deal.
Nov 02, 2008 | Hyundai Motor 2000 Tiburon
Won't Spin the water out...
Hiya WRock04... would be nice to have make and model.. otherwise.. look to replacing the brushes in the motor if the machine has done relatively little work... 3-5 yrs in some cases... otherwise a new motor unfortunately may be required.. specially if you can smell burning!!
regards Faggly
Mar 19, 2008 | GE WBSR3140DW Top Load Washer
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
130 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
