Question about SmartParts 3.5'' Digital Picture Frame Camcorder
3.5 digital frame by smartparts
I cannot view the pictures on the frame screen. I can view on my laptop if it is plugged in, but no on my frame. Help?
0 characters
1 Points
How to copy picture from laptop to usb
Just connect a cable to your computer from the device. Your computer should recognize it. At that point you can copy and paste photos to this device. It should of course prompt you to choose photos making this even easier.
Oct 04, 2012 | Insignia 7" Lcd Digital Photo Picture...
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
No picture on LCD screen
Flex wire connecting LCD to the camcorder is broken. I bought it in the repair shop and did it by miself. it's very common problem
Good luck
Aug 25, 2009 | Samsung Compact MiniDV Digital Camcorder
Picture in veiw finding keeps rolling so cant see what i am video
As you have noticed, this is not a battery problem but rather a screen problem(the view finder LCD screen) If the image is crisp and clear even though its rolling I would assume that the LCD screen connectors have come loose and can be resolved by taking them off and re-connecting them firmly. Make sure to turn off the camcorder before atttempting the repair just in case you want to do this yourself. I strongly advice you take professional help in fixing it.
Feel free to post back if you need more help.
May 12, 2009 | Panasonic NV-DS65 Mini DV Digital...
View finder and screen no picture
Check out this...I have same prob, found info here:
Jan 21, 2009 | Canon MV630i Mini DV Digital Camcorder
How do i download my photos from computer to easyshare picture frame, the computer does not show what attachment i am using?
first check whether usb cableis attached and then open the picture frame and now u can start transferringpictures
Oct 15, 2008 | SmartParts 3.5'' Digital Picture Frame...
Digital camera
I think, its touch-screen control at LCD panel camera and can you see picture in small viewfinder?
May 18, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
No picture
Mar 13, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
No visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Sep 04, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
SmartParts 3.5'' Digital Picture Frame Camcorder Logo
18 people viewed this question
Top SmartParts Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a SmartParts Video Camera Expert? Answer questions, earn points and help others
