Question about Maytag MMV6178 Stainless Steel 950 Watts Convection / Microwave Oven
Replace Miraclon Heater
I need to replace the Miraclon Heaters in my microwave.
I don't know why my frigidaire gallery microwave FMT118EPB goes on but doesn't heat
the magnitron supply EHT isnt there
or the heaters connections inside the square metal box
have come loose
replace the magnitron is best and check the eht fuse {inline type usually}
Aug 13, 2014 | Microwave Ovens
Electric heater dead
obviously it needs replaced
Jan 22, 2013 | GE JE2160 Microwave Oven
Why do Magnetrons fail? I ask this question as my microwave (2 year old integrated microwave) had a Magnetron failure. Was cheaper to replace it. Got a new integrated one (different brand) and a week into...
I have checked the Magnetron, it had a zero ohm reading, changed the fuze again, powered the unit which is a Sharp carousel convection microwave oven model R-9Z00, all lights came on tried the oven on cake setting the heater came on to warm the oven, but as soon as the the magnetron switched on, Boof the fuze blew again.
Yeas I agree I will buy a new Microwave
Nov 01, 2012 | Sanyo Microwave Ovens
We had an electric heater plugged in and on for 6 min at the same time our microwave was on. The microwave stopped working but the heater continued to work. It is not the plug or the breaker so it must be...
Check the power fuser in back of unit. You'll need to take the screws out and open it up. If your not comfortable with this you may want to call a technician to come out.replacing that blown fuse will fix your problem. no need for you replace the whole oven.
Jan 21, 2011 | Whirlpool Microwave Ovens
I have a Inverrter microwave oven that is displaying this code H98 on the screen and wont come on unless i hit stop then it will stop after 20sec what does this mean
The problem is likely to be a magnetron fault. The heater, as a magnetron is a thermionic tube, is not working either because the invertor is not powering it or the heater is open circuit.
The voltages in and around magnetrons are LETHAL!!! If you understand about high voltages, disconnect the appliance from the power socket, check there is no residual voltage on the capacitor feeding the magnetron and diode if there is discharge it in a safe way. Disconnect the magnetron and measure the resistance between the contacts of the magbnetron. There should be a low resistance, say 1/2 to 1 Ohm. If there is a high resistance, the heaters are open circuit - change the magnetron. If the heaters read OK the invertor is faulty - change the invertor.
I hope this helps and BE CAREFULL!
Oct 22, 2010 | Panasonic Microwave Ovens
Newly installed GE profile pem31 microwave starts as soon as plugged in and won't clear or shut off with the key pad. It is not heating but light is on and making noise.
hello,
this is a simple function that you should be able to carry out your self
from the statement above this means that your oven maize have disconnect from the element position i.e the wire have been disconnected from the heater
what you need to do is that unscrew your microwave trace the wire to the heater you will surely fine were the wire is been disconnected from the heater
then you have to huck up the wire back to the element (heater) the wire mention above will be in red and others can be in different color
please when doing make sure that all form of power supply is disconnect from the microwave to avoid accident
thank you and thanks for using fixya.
May 02, 2010 | GE Profile Spacemaker II PEM31 Microwave...
How do I test a magnetron
its best not to check a mag when voltage is appliaed
the best wat is to ohm it out
the two pins should read continuity, the each to the frame, this should read open,
Oct 13, 2009 | Microwave Ovens
Power loss then surge GE JE 1860 Microwave
Well it does appear that you have an intermittent problem. I do not think that there is a loose ground problem, but there is a thermal switch attached to the case of the magnetron that resemble the thermal switches in wall gas heaters. Like the one in wall heaters they tell the heater when to shut off and on. If that switch begins to open or is trying to open it will make it seem like your microwave wants to shut down. Of course that is just one solution which I think is the best. By the way that thermal switch only has two wires that go to it and resembles an oversized watch battery when it is out. What could cause that also is if those two wires which are connected with plugin spade terminals have become loose due to the vibration of the magnetron over the years. To cover all your bases at once, with the power off, take the cover off and reseat all the spade connectors that you can see and get to. Anything in line with that switch or with the power coming in at all can cause the same thing. Let me know if there is any other question that you have.
Feb 09, 2009 | GE JE1860 Microwave Oven
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Maytag MMV6178 Stainless Steel 950 Watts Convection / Microwave Oven Logo
102 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
