Question about Midland 75-822 40-Channels Handheld CB Radio
75-822 midland radio
I'm getting regular FM radio frequencies on my midland radio, and i'm not getting the cb frequencies any longer. can you help?
    Novelist:
    Champion:
  • 211 Answers
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Midland 75 785 purchase from us will it work on uk channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
Midland 75-822 no transmission in FM? why?
there is no transmission on FM because CB is at 26 to 27Mhz on the AM Band and as with your car radio FM starts around 88Mhz. the other reason is tha one one modulates amplatude(AM) slightly to cary the signal, FM modulates the frequincy slightly to carry the transmission.
if you want to talk on FM you might want to become a Amateur "Ham" Radio Operator.
Nov 03, 2010 | Midland 75-822 40-Channels Handheld CB...
How do I get back to regular CB channels on the 75-822? All I can get is 27.xx and 26.xx. Where are the 1-40 channels.
I'm guessing that you bought the CB from a person not a company the CB band is between 26Mhz and 27Mhz unfortunately your CB was Modded to talk on Ham radio frequency's what i would suggest is one of two things if you are good at electrical soldering get a schematic and take out the mod or look on-line for a ham radio store like ham radio outlet near you and see if they can un modd it.
if you bought it from a store return it or talk to midland to see if they can fix/reset it at http://www.midlandradio.com/Contact-Us
one other thing until the radio is fixed it is not FCC part 95 or 97 compliant and is therefor illegal to transmit with it
Sep 04, 2010 | Midland 75-822 40-Channels Handheld CB...
Will the midland 4001 still work in the uk?
While it will "work" if used to talk with another US CB model, it is not legal. Also, UK CBs use FM modulation while the US versions use AM. Even if they are on the same frequency, they cannot communicate with each other.
For a good discussion of this, look at the following link:
http://en.wikipedia.org/wiki/CB_radio_in_the_United_Kingdom
Feb 11, 2010 | Midland 4001 40-Channels Base CB Radio
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
How can you talk to cb radios?
with another CB radio only. A midland 2 way radio is gmrs and is a much higher frequency then CB. not compatible.
Sep 25, 2009 | Midland LXT310 2-Way Radio
Audio playback through speakers
HELLO
This happens because of the close proximity of the CB transmitting antenna to the car stereo antenna. I don't know for sure what country you live in, but if your country's CB system uses AM as a transmission mode it is well known for breakthrough on audio systems etc. In the UK, we have FM on CB frequencies which is less-prone to giving interference.
You could try ferrite rings/clamps on the car stereo antenna coax cable, power cable and also on your loudspeaker cables too. Apart from that - that is all you can do using it mobile!
GOOD LUCK
Sep 02, 2009 | Midland 1001Z 40-Channels Base CB Radio
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Midland 75-822 40-Channels Handheld CB Radio Logo
387 people viewed this question
Top Midland Radio Communications Experts
Steve
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
