Question about Home Security
On my safe house alarm system, 49-470A, the lights on loop 2 and 3 are not on.
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
T replaced my thermostat on my 04 chevy trailblazer and now it wont turn over
did you check to make sure the battery is fully charged?
On some GM products there are 2 large metal GROUND LOOPS bolted on or near the thermostat housing. Those are the main computer grounds. They are important. Make sure if you touched them they are both back on and tight.
Aside from the ground loop thing above, there shouildnt be anything youi would touch in a thermostat change that affects the starter, so for ease...treat it as a starting problem. It needs BATTERY CHARGED AND CABLES TIGHT. It needs GOOD FACTORY KEY (No security light or key symbol flashing on dash!), It needs SHIFTER IN PARK/NEUTRAL or CLUTCH FULLY DEPRESSED, and it may need alarm cycled OFF/UNLOCK even if the car isnt locked. Id start there. If all that tests out, then you may have a failed component in the starting system or an issue with security that needs to be checked. But start with those, most sudden start problems will fall in there.
Dec 22, 2014 | 2004 Chevrolet TrailBlazer
How do I repressurize baxi 380 without manual or do not see loop anywhere in new house I bought. Where can I purchase manual and loop
To determine if air is in the system, attach a gauge and run the system running pressure should stabilize if gauge pressure bounces then that would indicate non condensables in system.
Sep 23, 2014 | Heating & Cooling
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
I move into a house that had a alam system by att
I assume that you do not have an alarm code to turn the system off.Contact the Professor and he can walk you through a defaulting of the alarmpanel.
AlarmProfessor.net
Apr 21, 2010 | Ademco CIA Modem
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
How to reset the safe house alarm very old style model # 49-470A
i bought house alarm second hand and it has reset it self to factory setting 1234 but on pad its say called engineer to reset can you help
Jun 21, 2009 | Home Security
Carbon Monoxide wired to the house, no battery, beeping
the batt is used for backup. Its beeping to get you to install a batt
Jun 18, 2009 | First Alert SA302 Dual System Smoke...
Vista in Updating Loop 3 of 3 0% keeps rebooting.
nope it will allow the computer to fix itself not data loss at all. I've had to do this many times before. just try it and tell me your situation when you are done.
Sep 08, 2008 | Gateway Computers & Internet
Home Security Logo
229 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
