Question about Mintek DTV-373-D 37 in. LCD HDTV
TV w/ built in DVD
The remote and controls are not working except to turn the tv on and off--can't change over to DVD player and even the program guide from the satellite will not display--all of the remotes have new batteries and there is nothing in the way of the sensors
  • 3 more comments
  • getzen Dec 18, 2007
    None of the buttons on the remote work. The dvd player won't operate, nor will the side buttons.
  • alexmira Dec 24, 2007
    remote will not work and dvd stuck
  • Philly_jon May 22, 2008
    I have the 32" model. First, the remote stopped working and volume buttons on top of set. Then, DVD got stuck and couldn't get it to play. Took tv apart and got dvd out, but tv still stuck in dvd mode, so can't use the tv any more. Basically no buttons are working anymore other than on/off. Do suggested instructions for fix work for the 32" model? Do repair shops fix these? Will it cost more than the tv is worth?
    thanks! Jon
  • BACCIALL Aug 09, 2008
    MY REMOTE IS TOTALLY NOT WORKING. I CHANGED THE BATTERIES THREE TIMES AND THERE IS NO OBSTRUCTION TO THE TV. THANK YOU. VIRGINIA
  • Michael Gesu
    Michael Gesu Sep 09, 2008
    all my controls are locked , the picture only shows a pad lock and nothing works, I thuing I have activate the parental control by mistake but now I do not know how to undo-it please help-me
What a crock of **** this is guys! This FIX is surly a sad work around for the poor! Replace the mother board and solve your problem the correct way. No need to butcher up this TV. Better still, buy a name brand TV and a service contract which will save you money in the long run.
Dan Jackson - CET, which means Certified Electronics Technician
Posted on Oct 06, 2010
  • ryan7
    ryan7 Jun 29, 2011
    its a perfectly good hack if you have no reason to scour the net and pay handsomely for a part that is just going to go bad again. I was in college when these TVs were given to me and buying a new mobo was impractical. I'm sorry that you feel your certification allows you to assert that you are much richer than the folks who want to try my workaround, but sometimes money can be much better spent than on a large namebrand TV set (such as paying to go to a very renowned college and obtain an electrical engineering degree :) )
    Problem Solver:
  • 14 Answers
Attn: RYAN
I am following your fix for the Mintek LCD's which are frozen in the DVD mode. Mine is a 26" model and I would like to follow the procedure of attaching the component wires directly to the component input terminal on the motherboard. Problem is, on this model, there are only 2 non-flat strands and 3 flat strands coming off the component input. Your instructions said that there should be 3 of each and that the input wires are to be connected to the non-flat strands and the grounds to the flat strands. Each of the flat strands on the right & left are long while the flat strand in the center is short. One of the non-flat strands in directly between the left and middle flat strand. From this arrangement it would seem logical that the three input wires should be attached to the the corresponding flat strands and the 2 ground wires from these input wires should both be attached the non-flat strand the is between them while the 3rd input wire and ground wire should be attached to the remaining flat strand and non-flat strand. Are you sure that the input wires must be attached the the non-flat strands? If so how should this be done given the set-up I described.
I'll look for your reply here on the site. Thanks
PS: If your fix works it will be a god send to all those who have these frozen Mintek units and they are legion!
Posted on Mar 11, 2008
Ryan7 has a workaround which lets you watch any source with component video output. The Mintek TV upscales any format to 1080i, so it's quite a useful hack. It is not a perfect solution, but better than none.
Here is what I found so far.
It seems like the remote and buttons are being sensed by the main controller, since the ON-OFF function works from the remote.
The buttons on the TV itself are also sensed. When you turn the TV on, it first goes to STANDBY mode (red LED). At that point you can push any of the control buttons and the TV will switch to ACTIVE mode (green LED).
Bottom line is - the controls are not totally dead!
The remote control and the keys are all serial inputs to the same controller. It seems as though the controller can read them but no action is taken, including no display of the function activated (volume bar, etc.) so it's likely not a hardware but a software problem.
Since most units are stuck in DVD mode, it makes sense that the culprit is some signal from the DVD player. You'll notice from Ryan's solution that the DVD player is self-contained, i.e. it decodes the picture internally and sends it to the motherboard on the component wires rather than output raw digital data and have the same MPEG controller on the motherboard decode the picture locally.
This is a very poor integration of the two units. I would guess that a problem in the DVD develops after some time and it sends the wrong handshake signal to the motherboard. You'll notice that unplugging the DVD data cable "kills" the set altogether - it will remain in STANDBY mode whatever you do.
Perhaps someone with more time than me can track this issue or find a replacement DVD player, which must conform to the same handshake protocol.
Tracing would involve putting a scope or a logic analyzer on the handshake signals between the DVD and the motherboard. This may turn out to be a very trivial fix.
Posted on Nov 18, 2008
    Problem Solver:
  • 11 Answers
I have the same TV with the same problem. I was able to fix the television as well as two 26" Mintek TVs this way. This is a very lengthy, complex fix that requires some electronics know how and skills with a soldering iron and I highly recommend reading through this before jumping in. It also makes the TV lose functionality of the built in DVD player, the cable tuner, every input except component, and speaker functionality (so you'll need a receiver and speakers or some sort of powered speakers for sound). But it's much better than letting the $1200 TV gather dust in the basement. So if your feeling daring, give this a try:
First, the TV needs to be stuck in DVD mode. All I had to do was put a DVD in. Be mindful that you'll have to take the DVD player apart to get the DVD back, but this fix requires you to take the DVD player apart anyway.
Next, you'll have to take the back off the TV. It goes without saying that the set should be unplugged first. Also, the screws for taking the stand off are in the back of the TV and not in the bottom of the stand.
When you get the back off, you may want to short out the power supply capacitor. Take an INSULATED PLASTIC or RUBBER screwdriver or other tool and bridge the two leads on the power supply capacitor and be sure you don't touch any of the metal part of the screwdriver while you do it. A large spark is normal. If the TV has been off for some time there may be no spark at all. If you don't want to do this/can't find it capacitor/don't know what it looks like then just be sure to stay away from the immediate area where the AC cord goes into the TV.
Next, continue to remove panels until you can see the main "motherboard" of the television (the one all the inputs on the back of the TV are attached to. You'll have to disconnect some wires to get to it; most have a plastic interconnect, some grounds have a spade connector that's screwed into another part of the TV. Masking tape and colored markers go a long way when helping you remember where each wire goes, too. When you get the central board, take note of the wide, thin group of wires running from the motherboard to the DVD player (it's an IDE cable, the same kind used in computers, Google it).
Take out the DVD player and begin to take it apart, noting where the IDE cable connects. Also remember that you have a DVD stuck in the player. When you can see exactly where the IDE cable connects, look very closely at the board where it connects. You'll see, in extraordinarily small writing, labels for each wire of the IDE cable. Look for either the Y, PB, PR, or Y, CB, CR labels. Mintek only uses one label, but I can't remember which it is. You'll notice that each of the aforementioned wires has a ground wire right beside it labeled G or Gr or - or something obvious.
Use your colored markers or some other way to mark the Y, PB, PR wires (or Y, CB, CR wires) and their grounds. I drew a diagram on paper and counted over the correct number of wires (only because I was out of colored markers :) ). Just make sure you know which wires on the IDE cable are Y, PB, PR (or Y, CB, CR) and which are their grounds. Next, disconnect the IDE cable from the DVD player and use a knife or scissors to cut off the connector.
Here's where it gets very TEDIOUS, but you have a couple of options. I'll go over the easiest (and worst looking solution that probably won't last as long) first. It involves splicing a set of component cables to their respective wire and ground on the IDE cable. The cables will have to be long enough to reach your DVD player/cable box/satellite box/receiver or whatever you want have hooked to your TV. You also have to either leave off the small plastic rear panel or cut a hole in it for the wires to come out of the back of the TV. To fix the TV this way, use a knife to cut the connectors off one end of a set of component cables or 3 RCA cables (they both do the same thing, component cables are usually shielded better). You'll see two wires within each cable when you do this. One is in the middle and is insulated from the other, which runs around the inner one. Separate each strand of wire from the GREEN component cable (or whichever color you want to use for Y if your using regular RCA cables). Tin each strand with solder. Now find the the wire on the IDE cable labeled Y and it's ground. Cut the insulation off those wires (making sure to keep them separate) and tin them with solder. Solder the Y cable to the inner wire of the Green component cable and the ground to the outer part. Use electrical tape to insulate the wires from each other. Now do the same thing with the PB (or CB) and BLUE component cable and the PR (or CR) and RED component cable. Remember the inner wire of the component cable is the one you solder the signal carrying wire to and the outer wire of the component cable is the ground.
Now the second (and best solution that will last the life of the TV if done right) way is much more frustrating. It involves soldering the Y, PB, PR (or Y, CB, CR) wires of the IDE cable to the inputs on the back of the TV. It looks much better this way--the wires won't get pulled loose (they'll be concealed within the TV, and your friends won't notice that your TV has been butchered. You still need to cut the connector off the DVD end of the IDE cable. Find where the component input on the back of the TV is. There's a green Y connector, a blue PB/CB connector, and a red PR/CR connector. On the motherboard side of the connection there are some vertical strands of metal connecting the component connectors to the main board. There's a flat metal strand and another (not flat) metal strand for each of the component connections. The flat strands are for the grounds, the strands that stick out a little are for the signal carrying wires. Just solder the Y wire on the component cable to the GREEN component connector's non-flat strand (there's not much of another way to describe it) and Y's ground to the flat strand. Do the same for the PB (or CB) wire on the IDE cable to the BLUE PB/CB component connector's strands, and the PR (or CR) wire on the IDE cable to the RED PR/CR component connector's strands. HERE'S A TIP: when you solder to the strands, be sure to tin each wire AND the strand first. Also, it's best to have someone hold the TV upright while you solder, to keep all the solder from running to the bottom of the strands.
You may want to test the TV and make sure there are no grounds and that everything is connected before you put the TV back together.
You can also hook up the speakers to an unused RCA input using the same sort of method. This way you can hook up an amplifier or receiver to an RCA input to send signal to the TVs speakers.
Understand that once this is done anything you hook up to your TV will have to be hooked up using a component connection. If you have a satellite box or something that doesn't have the component output, you'll need something to convert. MOST DVD recorders actually do this. The best thing would be to buy a home theater receiver with video conversion, that way you have something to power your speakers AND you can, once again, hook anything up to your TV (through the receiver). The Onkyo TX-SR605 is a GREAT choice.
This really does work, albeit transforming the TV into a monitor (no tuner, no DVD, no sound, one input). Oh, one last thing: if you have the 26" model Mintek TV with the same problem, the fix is exactly the same, only much easier. Instead of working with an IDE cable to hassle with, there's a separate cable for each Y, PB, PR (or Y, CB, CR) signal. And it's labeled right on the main board of the TV, so you don't even have to fool with the DVD player. The DVD player is much more difficult to take apart on this model, though, so tough luck if you got a movie stuck in one.
I hope this helps you guys. If there's anything you don't understand, look it up on Google or Wikipedia. If you scour the net and still can't find the answer, I am truly sorry; I'm reluctant to put my email on this page for fear of spam. I wish now for the life of me that I'd thought about this site and took pictures when I fixed these TVs. If I ever get my hands on another one I will take pictures and post them!
Have a great day, be smart when working with electronics, don't blame me if you do something wrong and mess up your already messed up TV.
God bless,
Ryan
Posted on Feb 12, 2008
  • ryan7
    ryan7 Mar 11, 2008
    It may be a little different on the 26" model. It's been several months
    since I did the repair so my memory is a little fuzzy. It sounds like
    the non flat strands are a common ground and the flat ones are the hot
    wires. The best thing to do would be to take a multimeter and test for
    continuity on the center of the RCA jack and the flat strand of metal.
    If you get a reading, that is where the input wire should be soldered.
    More than likely you're correct and you should proceed as you found
    logical.
    All you're really doing is making a new connection for the component input on the back of the TV. So just make sure that each hot wire from the DVD player
    will be on the strand of metal that corresponds with the hot wire from
    the component RCA jack, which is the center part of the jack, not the
    outer metal sleeve. In theory you could just attach all of the grounds
    from the DVD player to any metal part of the TV; I do not know if this
    will work however because the set might have a failsafe on the
    motherboard, not allowing video pass through when grounds are not
    detected.
    I hope this helps! And please let me know if you get it working or have any other issues.
    Ryan
  • realmanwt Oct 07, 2010
    I TRIED THIS AND IT DIDN;T WORK ,IT STILL SAYS DVD CARD AND NO SIGNAL.
    WENDELL
2 Suggested Answers
SOURCE: TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Posted on Sep 06, 2008
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
Living solutions Jumbo remote programming
Jumbo remotes all seem to come from the same source regardless of the "brand". I do not see a code listed for your Trutech TV so you will have to do a code search. To do a search:
1. Turn on the TV
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the button
3. Press and release the TV button. The indicator blinks once.
4. Point the remote directly toward the front of the TV
5. Press the on-off button (top right) down until the indicator stays on
6. The indicator flashes until your TV turns off.
7. Press the ENTER button to store the code.
If the TV code is correct, you should be able to control the built-in DVD using the appropriate buttons on the remote. You just have to press the DVD button to do this.
Dec 24, 2013 | Universal Remote Control Hampton Bay...
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
TV w/ built in DVD
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
I need a code # to program my Universal RCA remote for my Prima TV and my DVD player
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
Jul 04, 2008 | Televison & Video
Mintek DTV-373-D 37 in. LCD HDTV Logo
1,964 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
