Question about Garden
I have a 6hp Craftsman 6hp Mulcher 21" Lawnmower' about 8 years old that has lost its spark, replaced the s/plug removed the flywheel, checked the wire at the magneto end, checked the wire at the shutoff switch,still no start! any good IDEA'S?? Thanks John.
  • 279 Answers
The only thing I can think of off hand is the flywheel key. Take the flywheel off and check the key. If it is broken, sometimes you cannot get a spark. Sometimes it will just backfire. Check it and I hope you are sucessful...Lee
Posted on Sep 23, 2009
Why is oil running out of spark plug hole 6hp. craftsman lawnmower.???
If you have not over filled the oil sump, the only other possible answers; bad oil ring on the piston, oil seals in the heads are bad. These are the only ways oil can get into the combustion chamber.
May 05, 2015 | Craftsman Garden
Craftsman 6hp.lawnmower oil pouring out of spark plug hole
Either someone put to much oil in it or a piston seal has failed. Try removing some of the oil and cleaning out the spark plug port and spark plug (maybe replace the spark plug with a new one. If it is a blown piston seal take it in for service.
May 05, 2015 | Cars & Trucks
Not getting spark in craftsman tractor lawnmower
How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
May 06, 2014 | Briggs & Stratton Briggs Stratton...
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
21 inch craftsman mulcher mower, if it does not ha...
yes,the magneto on the flywheel will create the energy to make voltage for spark
May 21, 2010 | Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Apr 15, 2009 | Craftsman Garden
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
