Question about Passport 8500 Radar Detector
Service required Hi: After i reprogrammed my escort 8500 radar detector, a message saying "err 3 cal" is on the display. Please help. Thanks. migrivera@coqui.net
  • dillon1966 Apr 28, 2008
    i held down all three buttons and too got the cal 3 warning...did anyone ever answer you?
  • 3 Answers
Hold down all three buttons and the device will reset itself.
Posted on Mar 20, 2008
My escort passport 8500 says "service required" after it starts up. what do i do?
Your radar detector is detecting a problem with part of the circuit during the start up - or boot sequence. Typically, these complex devices run a quick diagnostic check when starting up. If any result isn't as expected, you get a warning and in this case - a message indicating it needs servicing.
There is little that you can do to the detector to locate the problem; much less fix it. You could try to shut it off and turn on again to see if the problem goes away - but it probably won't. Your best bet is to return it to the factory for repair. You could continue to use it - but if the part of the detector that failed has to do with displaying or detecting radar sources, you may be in for an expensive surprise when you get pulled over for speeding.
Contact Escort radar customer service to go over your options.
I hope this helps - good luck!
Nov 15, 2010 | Passport 8500 Radar Detector
Says to get service
The service message indicates something isn't working as expected. This usually happens right after powering on, when the detector runs its self-check and receives an unexpected result. Continuing to rely on this device for radar warnings could be expensive.
Contact Escort Radar Support to arrange for service to restore reliable operation.
I hope this helps.
Sep 23, 2010 | Passport 8500 Radar Detector
My escort passpor says service required
Without knowing exactly what model you have, I strongly suggest going to the manufacturer's website:
http://www.escortradar.com/customer-service.php
and select " Click here to chat with a customer service representative live"
May 01, 2010 | Passport 8500 Radar Detector
My 8500 Radar more and more often displays service required message. How do I fix it? Thanks
This is due to failing the calibration test.Perhaps you can reprogram it or will have to return for sevicing.
here is the brochere link.
http://www.escortradar.com/pdf/8500x50manual.pdf
Oct 09, 2009 | Passport 8500 Radar Detector
Passport Radar service required
The internal diagnostics have detected a problem with the detector. You should contact Escort Customer Service directly for assistance, below:
Sep 27, 2009 | Passport 8500 Radar Detector
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
Display won't light
This is most likely due to a cold solder joint for one of the display leads where they are soldered to the edge of the circuit board. Or, possibly, the display itself has gone bad.
May 27, 2008 | Passport 8500 Radar Detector
Service Required on 8500
Hold all THREE buttons, one is located on the front right of the detector, while turning the detector on.
Aug 12, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
679 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Steve
Marvin
Marvin
jason
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
