Question about Samsung SP-R4232 42 in. Plasma HDTV
When Im watchin TV sometimes I see Blue patterns appear on differnt parts of the screen
  • Samsung Master
  • 3,866 Answers
Couple issues with this. I do not think I will be able to 100 percent nail this down as I cannot see these patterns But here is what you can do to check.
1. Try a DVD and see if these come back
2. Try letting the TV set off for 30 mns or more
3. if these do not help you may have a bad decoder or a plasma screen that is defective but I would Rule out the decoder first.
Good luck
When in doubt take it ot a technition locally.
Posted on Sep 23, 2009
I cant hear anyting on My toshiba when im watchin tv but if i put my bluray i can hear it bt not when im watchin tv
Please make sure your audio cables are connected properly from your cable box or DVR to your TV. Let me know if you need more help.
Nov 27, 2012 | Televison & Video
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
What would cause my jvc tv have a green tint
It sounds like you can have optical engine issue. That's if green tint was show up very gradually, until one day it really caught your attention.Normally some parts of the screen more green than other. It should get progressively worse. To solve this issue optical engine have to be replaced. It is pretty expensive repair if your TV is out of the warranty.
In case if tint appeared suddenly in one moment - you can try to check component cable connection on the back of your TV if you are using one ( green, blue and red colored). Sometimes it's loose or after disconnection people reconnecting it in wrong way.
Experienced tech will determine if optical engine is bad by running test patterns in special service mode. If green tint present on Grey scale - optical engine is bad.
Sorry for bad news.
Regards.
Russ.
Apr 06, 2010 | JVC AV-56WP74 56" Rear Projection...
SAnyo 32" LCD: Pattern appearing on the screen after sometime
im sorry friend, your processor over heated and the Processor is toast, they will fix it and it will work for a month or 2 then it will **** out on you again. so best to get another one. i know this problem all to well
the reason the processor over heated is becasue the fan cut out, prolly seased up.
May 02, 2009 | Sanyo DP32648 32 in. LCD TV
Unlocking the parental control
my jensen ts2750j screen turned blue and a red lock is in the corner... how do i get it off
Nov 06, 2007 | Jensen TS2750J TV
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Lock jensen ts2750j
press the diplay button for 3 seconds
Feb 25, 2007 | Jensen TS2750J TV
Blue and yellow picture
Does it look like these?
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 29, 2006 | Hitachi 51S500 51" Rear Projection...
Samsung SP-R4232 42 in. Plasma HDTV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
