PLUMBING PROBLEM. THE H.W.SUPPLY PIPE TO MY BATHROOM SINK HAS RUSTED INTERNALLY RESULTING IN DECREASED WATER FLOW. IT IS G.I. X 3/8" d., ABOUT 2' 0" ABOVE THE FLOOR AND IS WITHIN THE SINK WALL. IT IS TOPPED WITH A ELBOW AND A 6" NIPPLE PROJECTS THRU THE WALL AND CONNECTS TO THE SINK WITH A RIGHT ANGLE SHUT-OFF VALVE. I REMOVED THE VALVE AND TRIED TO **** THE PIPE OUT WITH A COAT HANGER, BUT THE WIRE COULD NOT MAKE THE TURN IN THE ELBOW. HELP! I DO NOT WANT TO DAMAGE THE EXISTING WALL OR FLOOR TILE, AND I DO NOT WANT TO INSTALL AN EXPOSED PIPE
  • ray5208 Sep 24, 2009
    THANX FOR THE INPUT.
    FURTHER INFO: I HAVE PREVIOUSLY REPLACED THE HORIZONTAL PIPING TO THE 3/8" SUPPLY
    LINE SO THAT THIS SECTION IS ABOUT 2'6" IN LENGTH. BEFORE I GO THRU CHILD-BIRTH PAIN WITH NEW PIPE, I WILL TRY A LIQUID. I CAN REMOVE THE TURN-OFF VALVE UNDER THE SINK, ATTACH A HOSE AND FUNNEL TO THE NIPPLE AND POUR FROM THERE. DO KNOW OF ANY STRONGER LIQUID/CHEMICAL I COULD USE?
    THANX AGAIN, RAY ADLER
    President:
  • Washing Mach... Master
  • 1,714 Answers
You could try using muriatic acid, (very powerful) and a spray bottle to try to force some acid into the pipe. Let it sit in there for a while then put a bucket under the 6" nipple and let some water flow, bringing out some of the rust. Then put things back together. You won't get it all but it may help open things up a bit.
Posted on Sep 24, 2009
  • Craig Butler
    Craig Butler Sep 25, 2009
    Listen, that muriatic acid is as strong as you can get. Anything stronger would dissolve the pipe! Be careful with it and don't breath the fumes they are powerful.
    President:
  • 2,976 Answers
If you're using 3/8" galv and it's corroded to the point, that you need to run a wire through it to get water flow, just cleaning out the last 2 feet won't help that much. The only way to fix it is to uninstall the pipe, starting at the top and go down. This will give you the holes needed to run new pipe. You can run copper but since you can't put any holes or access panels in for soldering access, you will have to solder threaded ends onto the pipe. Thread the pipe through the old path and tighten it up. My house was built in 1925 and I had to do the same thing about 10 years ago. I used 3/4" copper for strength while tightening. Put 2 SMOOTH layers of teflon tape on the male threads before you push the pipe through. A real thin layer of sealant on top of the tape will help, since you won't be able to get right at the joints to hold both pieces with a wrench.
The only other POSSIBILITY to get more water through the line is to fill it with vinegar and let it soak overnight. To do this, you will have to remove the pipe at the heater and the top, drain it, plug the bottom and pour vinegar into it from the top. After 24 hours, drain it, reconnect it and flush it out without the aerator on your spigot.
Posted on Sep 23, 2009
Just bought 4 moen Oxbridge bathroom sink faucets. Water pressure is very low compared to old faucets. Checked the aerator but no adjustment is available. New shower head is the same issue.
These days, you may find a disk with a small hole intended to restrict flow. It may be installed above the aerator. Check the flow with aerator removed.
Aug 13, 2017 | Moen Plumbing
Cold water pipe into bathroom sink is very slow. Good pressure everywhere else
Take the supply line off the valve under sink and put bucket close to valve turn on and see if pressure is good. If not you need to replace. if its good then you need to remove valve at knob and check for dirt or grit. I usually will turn the valve on and off under sink real quick to clean out. replace any washers or o rings while you have it out.
Jun 21, 2017 | Plumbing
How do I set up the plumbing to convert a single bathroom sink to a double sink?
hot and cold supply is easy. You need to solder in a copper T-piece, and to that add a short length of copper pipe with an isolation valve and then connect that to a flexible braided pipe to the faucet.
Waste water not quite so easy. Have both P-traps fall to a cross pipe that goes to your existing waste.
A plumber could do the job in an hour and a half.
Oct 29, 2015 | Plumbing
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
Water from bathtub faucet is orange when first turns on. The plumber says it is not rust. The pipes are all copper. It becomes clear after about 30 seconds but by the next morning the water is cloudy...
You didn't mention the source of the water. Is this a well or connected to a water system? If is a well you might need to install a filter on the line coming into the house. Does the orange water stain or have any odor? It is possible that there is a loose connection somewhere allowing sediment to leach into the line when there is no active flow.
Oct 28, 2012 | Hansgrohe Plumbing
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
We just installed a new moen 4 inch centerset Lindley faucett with drain for our bathroom. The drain piece has 2 molded holes in it. We are experiencing leaks from this pipe. How are we supposed to fix...
Ok I asked for some more information, but let me give it a try to help you with what I have here.
The two holes are for water to drain out of the over flow of the sink. If you look at the sink on the front side you may have to feel but there is one hole or up to three little ones. They take off water when someone walks away with the faucet on and they it goes down the drain and not on the floor.
Now if the sink your putting this in is a steel sink that does not have an over flow it will leak and you need an other drain system that is made for a sink with no over flow.
Places like manufactored homes, boats, campers would be where you would find a sink that does not have a over flow. Now with the over flow out if the sink does is not about1 inch thick.
if not use try more putty
Sep 12, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
