Question about Kirby Ultimate G Bagged Upright Vacuum
Belts I have recently bought new belts and when I installed the green light only comes on sometimes and I can smell rubber burning. The last belt broke very quickly so I am assuming that when I put the vacuum back together I am doing something incorrectly. Can you help instruct me?
  • Anonymous Dec 29, 2007
    smell the belt
  • Anonymous Mar 09, 2008
    Changed the brush roll and new belt and now the indicator light does not come on
Recently received a kirby from mother in law and don't how to change the belts
Posted on Dec 28, 2007
  • 357 Answers
Here is the link to the detailed instructions for belt changing. When you take the brushroll out, make sure that the brushroll spins freely. If it doesn't it will burn up your belts and needs to be replaced.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Posted on Mar 15, 2008
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Bissell quickwash 1970E for carpets/hard floors won't come on
If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
Mar 28, 2014 | Bissell Vacuums
I love my floor mate which I bought last year. Now it is making a funny sound and has a weird burning smell. I was told to take it to a repair shop but before spending the money I want to find out if this...
It may be the belt. Sometime the motor spins but the belt is not spinning with it. This causes the belt to heat-up and burn/melt. The burned rubber maybe what you're smelling and sometime make funny noise and hard to push the vacuum.
Oct 08, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
GREEN LIGHT AND MOTOR
The green light is an indicator that your brush is rolling smoothly. If it starts to flicker and you smell something that smells like rubber burning you need to do a couple things; one is remove the roller and clean off all of the hair, string, etc. Next you want to replace your belt. Just because the roller isn't turning doesn't mean the motor and the belt aren't either. If your roller gets jammed your belt will continue to spin and it will eventually wear down in one spot and break. Replace the belt, clean the roller and your should be fine.
Apr 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Why is my making a really loud noise and smells burnt when I turn it on. I have a new belt on it.
Improper installation of belt can result in a loose or off center belt which will flap and make lots of noise. It can also result in the burning rubber smell. The belt is probably ruined now, and will need to be replaced again. Make sure new ones are installed and centered correctly.
Oct 03, 2010 | Sharp Vacuums
How loose can a v belt be? I have a burny smell after vacuuming.
IF YOU HAVE A BURNING SMELL THAT SELLS LIKE RUBBER THEN ITS TIME REPLACE THE BELT,MAKE SURE YOU CLEAN THE MOTOR SHAFT OF THE OLD RUBBER OTHERWISE THE NEW BELT WON'T LAST VERY LONG.YOU CAN USE A SMALL PIECE OF EMERY CLOTH TO CLEAN IT DOWN TO THE POLSHED FINISH
Oct 01, 2009 | Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Install a new 4476 belt
What kind of vacuum is it you have?
Nov 30, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
158 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
