Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do I turn on scanner function on epson cx5800F series
  • 95 Answers
Download epson scan and install it to your computer. go to www.epson.com and choose your site and model to have the sufficient driver you need
Posted on Sep 23, 2009
How do you get a scanner on a EPSON Stylus CX3900 Series to work on a network?
No. Don't see any network function on specs. Only USB
http://www.epson.com.au/products/multifunctional/styluscx3900_specs.asp
Jan 19, 2013 | EPSON Stylus CX3900 Series
I have an Epson CX5800F Stylus all in one. Can I print in black and white if I am out of one or more ink colors?
Hi
NO WAY!
You should have all the inks to make the printer work. If any of the cartridge is low on ink you can still manage to work. But completely empty will not work.
Jul 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Scanner error on PC says "cannot properly communicate with scanner. Make sure the scanner is on, properly connected and properly set up to scan." the test scan works and i can see the image. the printer...
Try and open MS Word and import a picture into a document via scan, follow the prompts in Word and it should work fine. If you don,t have MS Word you can download a completely compatible application at Open Office.org. It also has the same functionality is free and allows you to save documents as .doc, .xls, etc. Sometimes a scanner requires additional software or drivers in addition to functioning as a printer. I have found scanning internal to an application a workaround or test for the scanner. If this works I would review the installation or contact the manufacturer or website. Or post and we can give it another try.
Jun 04, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Remove empty print cartridge
Turn the printer on, when time is displayed press the setup button. Press the up/down arrow buttons to get to "5. replace Cartridge" and then press OK. Open the scanner unit and lift the lid off the ink carriage unit. Remove the empty cartridge and fit the new one. Make sure the cartridge and carriage cover click down into place, close scanner unit and press OK. The user guide with pictures can be downloaded fro Epson here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58607&prodoid=58654753
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How to use scanner on a Epson Stylus CX5800F
follow this link --
http://files.support.epson.com/htmldocs/cx58f_/cx58f_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Dec 25, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Does this unit have fax capabilities
CX4800 is an all-in-one printer copier, scanner, printer at one. It's unfortunate that CX4800 doesn't have any fax capabilities. Epson has variety of All-in-one printers that has fax function such as CX9400F, CX9475F, CX5800F and CX7000F.
If you have future concern feel free to contact us again. Thank you so much.
Jun 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
I need a cd
thats ok tell him to go to epson.com website download latest driver anyways ok work better for him thx nick
Feb 10, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Changing ink cartridge/s
The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
Dec 11, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
