Question about Planar XP17W (White) Monitor
Hi, I cleaned and changed a fan in my computer, now when i start up the monitor will satrt also then in a few seconds it goes blank, have tried to turn on and off but that doesn't do it. I"ve performed this several times before without incident, What could the problem be? the monitor is just over a year old.
    President:
  • 2,976 Answers
It is quite possible, that the monitor plug in the back of the computer isn't seated properly. If the cord can be detached from the back of the monitor, check thet too. Look for pins that aren't straight too. This will prevent it from working properly.
If the cord is tight at both ends, you have a loose connection inside the PC itself. Look for ANY loose jumpers or wires on the boards.
Posted on Sep 23, 2009
Hp l1908w monitor
before goes blank does work ok for the few seconds. If not maybe does not get signal from the cable. The osd menus works ok?
Jul 02, 2014 | HP L1908w Monitor
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor goes blank after being on for 1 minute
it's not yr monitor problem. it's a basic system problem u need to clean yr ram or ser CPU internal Cables connectors or make sure yr pc is clean if yr pc has dust problem clean with Blower and remove dust then try it's help u..
if u don't know how to clean **** please don't do yrself.. contect yr engineer.
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | BenQ FP71G 17" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
LCD monitor turns off after 2 seconds from boot
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Nov 19, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Planar XP17W (White) Monitor Logo
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
