Question about Hunter 33202 Humidifier
How do I remove the cover to get access to the filter?
  • 496 Answers
Your user's manual should provide you with the information you need. If you no longer have the manual, here is a link for you to download one:
http://www.hunterair.com/ssi/pdf/hunter/33202-Owners-Manual.pdf
Hope this helps you... Good luck!
Posted on Sep 23, 2009
I have a basement dehumifiier and I think there should be a way to clean the filter but don't know how to go about it?
you can unplug the unit,then remove top cover rear screw,then 6 screws on side of front grille,then all screws around the rest of the units wrap around cover,being careful to not stress any wires in doing so,then carefully blow out inside components out with low pressure compressed air or a vacuum cleaner
Mar 25, 2011 | Whirlpool AD50USR 50 Pint Per Day Ultra...
How do I remove the thermostat cover to change the battery?
Many of the newer Honeywell models have a battery compartment that can be accessed without removing the thermostat.
Look for a small tab at one of the top corners of the thermostat. If this is not the case try pulling directly away from the wall at the bottom, then tilt up.
Aug 27, 2010 | Honeywell Power Humidifier: Furnace...
Making loud sound when running. It is on a flat hard suface. Sounds like the fan is struggling to work. How to remove the fan to see if this is the problem. Appears to be a sealed unit
The unit is not sealed. You'll find barely visible white covers over the holes where there are screws you can remove. Then the mid cover comes off and you can access the entire electronic configuration underneath including the fan. Looks almost like a PC fan but it is 18V. I am not sure where to find a replacement...:(
Aug 09, 2010 | Crane Hello Kitty Humidifier
How is the cover to the 550 Humidifier removed to replace the filter? elkandnlk@yahoo.com
The side opposite of the pipe inlet has a finger tip recess 1 1/2" from fron and runs vertical. Pull straight out
May 08, 2010 | Aprilaire 550 Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
House is too dry
remove the cover and replaced the water pad and clean the water guide on top of filter and lower drain case by drain hose,then make sure the fan is operating and the water inlet and outlet lines are lime build-up free
Jan 01, 2010 | Aprilaire 700 Humidifier
Aprilaire 760 won't start
No. when you remove the front cover it will automatically disconnect the power supply. Try changing the water panel and cleaning out the orifice and filter screens located in the water lines connected to the solenoid valve.
Dec 26, 2008 | Humidifiers
Filter
Lift the cover, remove the old wick and place the new on in its place.
Dec 09, 2007 | Kenmore 14410 Humidifier
Filter
If you email me at jennju@hotmail.com, I can send you a pdf of the manual for this product. I had the same model and was able to remove the fan cover by slightly twisting it and pulling up -- was able to clean the unit very well once I removed the cover! good luck...
Dec 03, 2007 | Honeywell DH835 Humidifier
Need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Dec 01, 2007 | Vicks V3100 1.2 Gallon Humidifier
Hunter 33202 Humidifier Logo
101 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
