Question about Motorola Mobility RAZR V3
Blank screen razr
Phone works but, I can not see who I call , or who is calling me, nor even anything in the screen, I have with it no more than 90 days
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
Blank, white screen on my LG CU 400
Yes. We repair problems like yous all the time. Please call or vist our location at 555 Broadway in Denver. A repair like that typicaly cost between $20 -$40 and takes no longer than an hour. We also warenty our repairs for 90 days.
Bill - Spring mobile - 720-274-2492
Jan 28, 2010 | LG CU400 Cellular Phone
I have an older model motorola razr that the screen went blank but it is stil working.
Yes this is the most common problem with the RAZR.
There is a small cable connecting the screen to the keypad part of the phone. This cable is called a flex cable and fits through the hinge of your RAZR so that the screen and keypad are connected even as the phone opens and closes on the hinge.
BUT, this cable often wears out or can even be severed even a slight bit, and the phone would then work, but only the bottom half, the screen would be dead. I fix this issue for people more than any other cell problem. You need to have the flex cable replaced.
Nov 28, 2009 | Motorola Mobility RAZR V3
My screen just went blank
If u have a Razor (As shown in the picture), If the mini Screen Works(When you close the phone) then then make sure the push down button((Turns off the main screen when you flip the phone closed) is not pushed down while the phone is open.
Hope this helps.
Jul 01, 2009 | Motorola Mobility RAZR V3
My screen has gone blank
you need to change your rebon thats oll
Feb 26, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Blank screen
you need to have the flexcable replaced.
Jun 29, 2008 | Motorola Mobility RAZR V3
Razr v3m
The Flex cable probably went bad on it and yes it can all of a sudden so this.
Mar 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
Blank screen
have the LCD replaced and that will correct the problem that you are having.
Feb 18, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3m - won't load mainscreen/turn on
It may be your card. Take the card out and try it again I had to do that and wait for a while for it to turn on all the way
Oct 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
