Question about Orion Car Audio & Video
Immediately blows 40A input fuse
An orion XTR275. Immediately blows 40A input fuse. With or without remote turn-on
  • 366 Answers
SOURCE: The big 40A fuse under the hood keeps blowing when
youll have to probe that elec.circuit to find what is causing your short
Posted on Feb 26, 2009
  • 541 Answers
SOURCE: I have an Orion TV1331. change to video without remote....?
The only way to switch it from TV to video is with the remote control. Orion did not have many onboard controls.
Posted on Oct 14, 2009
bhatgiri73
  • 106 Answers
SOURCE: orion TVD2710 will turn on and display on screen please wait
the lens must be cleaned....still proble replace the lens..
Posted on Jan 26, 2010
  • 2468 Answers
SOURCE: My chevy silverado keeps blowing the 40A fuse for the AC
the windings in the coil on the compressor clutch is shorted,you need to remove the drive pulley where the belts hook on the compressor,then unbolt the 4 bolts holding the coil assy
Posted on Mar 17, 2010
  • 20 Answers
SOURCE: 98 grand cherokee asd relay blowing fuse
The fuse it doing it's job, you have a short ( Wire that is connected to a ground, that draws too much power )
If you have an electrical schematic ( Repair manual ) find out which wires are connected to that fuse and check them for any chaffing, cuts, unnesassary twists, or corrosion.
If you have a ohm-meter, isolate the system ( by disconnecting the fuse, and other connections. Then check for any resistance on wires that should not be connected ( because you disconnected them ) by having one Lead on the wire's connector and the other meter-lead on your car's frame. A good wire will not have continuity if it is isolated.
Posted on Apr 10, 2010
20A ACC/cig fuse, 40A fan fuse (AC) keeps blowing on 05 Sebring.
Disconnect the cigar lighter and see if the short goes away, I will bet it does.
Aug 09, 2012 | Chrysler Sebring Cars & Trucks
My inverter keep blowing 40 amp fuses without load
Hi Trevor,
A 1000W can barely supply 5A at 220V, less than 10A at 110V. So if a 40A fuse blows, there is a serious problem and you should not attempt to use this unit after it has been checked by a qualified person. Please be careful!
Nov 20, 2011 | Sunforce 1000 Watt Pure Sine Wave Inverter...
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I cant change input without a remote how do i do this?
Unfortunately Orion has no other way to switch the inputs but with the remote. www.remotes.com has an original remote. Thanks
Nov 01, 2009 | Orion STV2763 27" TV
Fuse replaced but blows againwhen remote clicked for CT32SL14
This is a problem with the main poiwer supply. It could be simply a shorted rectifier diode or more complex. Without taking measurements inside the set or at least seeing what the condition is of the board, there is little we can do to help. This unit shoul dbe brought to a service shop with a request for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair. Expect to pay $50 or more for the estimate.
Dan
Aug 20, 2009 | Panasonic Televison & Video
I just had this thing running maybe a month ago no problems nothing working great. now about a month later its turning on then going off i seriously am retarded when it comes to this **** i had it hooked...
Hello bloodyspokes, For the amp to go immediately into protection, something is probably shorted, grounding out, or not grounding properly. First, remove and check the 40A onboard fuse just left of the power/ground/remote terminals. If the fuse is OK, disconnect the speaker wires and try powering up. If it powers up OK, check the speakers and wiring. If it doesn't, disconnect the inputs and try again. Check the grounds of both the amp and your receiver. If these check OK and the amp is still not powering up properly, it's most likely an internal component failure and the amp needs service. Hope this helps.
Jun 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Feb 25, 2009 | 1998 Chevrolet Blazer
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
Orion stv 2750 27" TV
if you dont already have the remote set up then find the codes and t it up. the remote should have a button that says either tv/video or input. depending on the tv it should take you to a few channels through this button. look for either input 1 or 2, or even GAME. these should be the channels it will play on.
Oct 26, 2007 | Orion STV2763 27" TV
Car Audio & Video Logo
117 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
