Hi, we have a PRO-930HD set with the separate media receiver and a Denon 5910 DVD player. For several years I have had continual problems getting the HDMI output on the DVD player to work with the 930HD. The DVD player is set to HDMI Y Cb Cr output, and the 930HD has HDMI enabled (with the 10-bit pulldown setting or the Auto setting). I cannot get an HDMI signal unless every time we watch a DVD, I turn off the display, unplug the MEdia Receiver for at least 10 minutes, and cycle through 930HD inputs (Input 1 and Input 3 are being used) and manually do trial and error with the Pioneer's HDMI settings, as well as turn the Denon DVD player on and off and power cycle it as well. I've also tried fixing the HDMI output to 1080i (native resolution of the Pioneer 930HD) or as low as 480i or 480p, which negates the advantages of the Denon 5910's scalar. Any advice about how to make these two devices work better together would be welcome. FYI, we have a TIVO-HD on Input 1 with HDMI and have no problems with it. We've also replicated the problem on an Oppo DVD player, and on two different media receivers for the unit.
  • sdrucker Sep 23, 2009
    Charlymonty,
    The Denon 5910 has HDMI v1.1 output, and the Pro-930HD TV has two HDMI outputs. The problem isn't that we don't have ANY HDMI output from the Denon to the Pioneer 930HD set, but that it only seems to work sporadically. I've tried different HDMI (Better Cables) cables as well, plus the obvious steps of plugging/unplugging both the DVD and media receiver and power cycling, as well as plugging and unplugging the cable connections between the units. The only other issue I could see is that I need about a 20' cable between the Pioneer's media receiver and the Denon. And the 930-HD supports up to 1080i resolution.
    I have a 20' HDMI cable. In our setup I needed a cable that was more than 12', so I bought a 20' online from Better Cables when we purchased the DVD player.
  • 360 Answers
I really have been thinking of your problem. The truth is, your doing about the best can be expected. What it is, is these two technologies that haven't been completely worked out. I only hope the newer devices do better at hand shaking and are able to get rid of these hang ups. The HDMI of the DVD player got rid of the analog to digital converters in hope of higher quality but, fails in communication between devices. I hope this helps you.
Posted on Sep 24, 2009
  • Richard Klein
    Richard Klein Sep 30, 2009
    I understand the problem of shutting the devices off to enter a different mode. It has to be done that way but, it should do better than what you encountered. Having such long cables require your device to supply even more to terminate the signal and the ports or jacks, we can't improve that much. I guess the only thing that I think will help is to upgrade the system.
  • 3,741 Answers
If the two device are not compatible with each other then it will not work on any resolution you set.and another reason is the connections not connected properly .check if any wire is connected loose also try interchanging the wires . -----------------Check your tv set capabilities. If your set supports 1080i then yes, you will see a modest picture improvement. Also, check to see you have an HDMI input on your tv. You may only have a DVI input. The only upgrade that HDMI offers over DVI is that it carries digital sound to your receiver which eliminates the need for extra sound cables. BUT, you will need to purchase 2 HDMI cables. ----------- Set-up
Another reason for the PRO-930HD’s trim profile is that Pioneer has put the connection panel in a separate box that goes in your equipment rack. A proprietary cable links the plasma to this media receiver, as they call it. The two-piece design allows for a cleaner look, since only the power cord and proprietary cable are attached to the panel itself, and it’s much easier to connect external equipment directly to the receiver. The IR port is on the panel, so you can tuck the media receiver away in a cabinet. Yet another benefit to this approach is that you can use shorter cables, which saves money and can improve the signal quality, especially with a digital video signal like HDMI.
Speaking of HDMI, the PRO-930HD has two of them—inputs, that is. It also has two iLink ports and three component video inputs, one of which is placed on the media receiver’s front panel, a decision gamers will likely appreciate. It’s worth noting that Inputs 1 and 3 on the back panel share a component video and HDMI input, so you have to choose one or the other via the onscreen setup menu. The default setting is component video for Input 1 and HDMI for Input 3. The media receiver also has an RS-232 port to incorporate the TV into an automation system, a 15-pin RGB connector for use with a computer and a PCMCIA Type II memory-card adapter that lets you display JPEG photos and slide shows.
Making basic adjustments to the PRO-930HD’s video and audio parameters is a straightforward process. The owner’s manual thoroughly explains the different choices, the onscreen menu is translucent and logically laid out, and the individual video controls don’t cover the screen, which makes it easier to adjust the picture. I began with video adjustments, setting up the HDMI and component video inputs using my Sony DVP-NS75H DVD player and test patterns from the “Video Essentials” DVD (DVD International). Pioneer has included six picture modes from which to choose: Standard, Dynamic, Movie, Game, User and Pure (which Pioneer says “reflects input signals as faithfully as possible”). In all modes but Dynamic, you can make further adjustments to contrast, brightness, color, tint and sharpness. I recommend you avoid the Dynamic mode; it’s extremely blue and shows a ton of edge enhancement. I ultimately went with the Pure mode for the HDMI input and the Movie mode for component video. Both look quite accurate by videophile standards and required only minor tweaks on my part. Some edge enhancement was still visible in these modes, which required turning down the sharpness control. You can turn this setting all the way down through the HDMI input; however, with component video, the picture gets noticeably softer if you set the sharpness control at its minimum (–15). I set it at –1 to remove edge enhancement yet still show all the detail in the picture. In addition to the above six picture modes, the PRO-930HD come ISFccc calibration ready, which adds two additional viewing modes, ISF day and ISF night. This calibration should be performed by a professional for further adjustment of the plasma's picture contrast, tint, color as well as to take into account the specific room environment.
----------------- thanks.this will help.keep updated.
Posted on Sep 23, 2009
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Denon DVD-5910 HDMI & progressive scan via component connector not working.
Please verify that the capability of your TV, AMP, and Source are all compatible on their settings prior to using progressive scan.
Mar 20, 2011 | Denon DVD-5910 DVD Player
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
When dvd plays radio comes through as well.
This unit needs to go out for service. There is an issue inside the circuitry in the unit.
Gary
Nov 22, 2008 | Denon AVR-2803 Receiver
Sound with HDMI but no video
the Denon does not pass 1080p change the output res from the DVD/PS3 or Xbox to 720p or 1080i will solve the problem
Nov 18, 2008 | Denon AVR-2807 Receiver
Denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Denon AVR-3801 Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
