Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cant print and im getting an error message
My Hp officejet 6110 all in one is giving me an error message that saids remove and check cartridge. I did as requested but it wont go away and it wont let me print
    President:
  • 1,653 Answers
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Posted on Sep 23, 2009
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
turn off the printer
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet is displaying a message "remove
Your printer is in Error mode.. Specially with black ink empty message. HP Printer is designed in such manner that it will not allow you do to anything if it gives cartridge error message on printer screen.
you will have to replace the cartridge and align the printer to get it working.
Regards,
Ron
Jun 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Error message: remove and check cartidge. I did this and even cleaned connector points. im only trying to use the scanner, but this is the first message that appears and I cant do anything.
removed cartridges, pulled plug out of wall, cleaned cartridges, and back of cartridge chute,
no help, plug in and same message, check cartridge,!,, there is a wire at back that could be stopping insert proper, but doesn't look like it, must be electrical or need new printer
May 14, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check cartridge
Replace all ink cartridges at the same time.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Flashing light and a message !
Hello patelmafat,
HP recommends to use genuine cartridges (not even refilled ones) to be able to print at desired quality. As you are using refilled cartridges, you may not be able to print in good quality and may sometimes, errors like you are facing right now, creep up. So , I would suggest you to get new genuine HP cartridges to avoid such issues. If you are facing the same issue even after you install new cartridges, please let update us so that we may proceed further.
thank you.
Oct 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
