Question about Oster 4093-8 Osterizer Classic Blender 2-Speed Blender
My blender stopped smells like plastic - Oster 4093-8 Osterizer Classic Blender 2-Speed Blender
    President:
  • 1,922 Answers
Your triac module has shorted on the circuit board
Posted on Sep 23, 2009
I have a breville kinetic blender - not used for a while. Gives a nasty burning smell when used. Anything I can do?
Unless it is food stuck around the blender bottom , you have parts burning up inside. Its not safe to use. Check to make sure it is clean top an bottom if smell returns stop using. Could burn house down.
Jan 29, 2015 | Breville Blenders
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
My vita-mix just stopped working, there is slight burned smell, I was blending walnut pieces with dates paste. Any suggestions?
If the burning smells like plastic then the walnut shells most likely put too much strain on the motor and burned it out. If the burning does not smell like plastic then you most likely have walnut shell grit jamming your motor.
This can be cleaned out by first ENSURING IT IS UNPLUGGED FROM THE WALL.
  • First remove the canister (if possible)
  • The remove the blade (if possible) check for a build up of grit between the blade and the shaft connecting it to the motor.
  • Check the channel the shaft passes through from the motor for large chunks of walnut shells or date paste.
  • Clean the canister thoroughly with warm water and leave it to soak overnight in a water/soap mixture.
If this has not resolved the issue then try to claim it under warranty or source replacement parts online.
Feb 28, 2011 | Vitamix Super 5000 Work Top Blender
The blender stopped working
the motor is burnt. replace with the same motor or have it rewound.
Aug 24, 2009 | Kenmore Blender Single-Speed Blender
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jun 23, 2009 | Kenmore 204101 Single-Speed Blender
Cuisinart powerblend 500 blender doesn't work
sorry to hear of your problem. Do not delay to contact cuisinart customer service to return this defective item. Here is the link
Any requests concerning product returns should be directed to customer service.
1-800-726-0190
customerservice@cuisinart.com
Jun 11, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Burning smell
That burning smell was possibly the motor windings burning out. If the windings have burned the blender will need to be replaced. Hope this has helped you today,.......... Sea Breeze
Please let me know if this answered you question.
Feb 01, 2009 | Hamilton Beach 52250 BlendMaster Ultra...
My nblender just stop working, power in was good, no reaction.
Switch must be bad, remove the four screws on the bottom they are under the feet, then check switches, and replace broken one.
Nov 19, 2008 | Vitamix 5000 Work Top Blender
Oster 4093-8 Osterizer Classic Blender 2-Speed Blender Logo
331 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
