Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven cleaning timer does not work - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Frigidaire Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Sep 30, 2010
Samsung oven display not working
The self clean setting on ovens should be labelled "Self Destruct". This often overheats the timer. This company does oven control repairs. You just remove the timer and send it to them. They repair it for $106 and send it back. There is no charge if they can't repair it.
Feb 02, 2013 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
The timer has gone on the cooker and I can't use the oven or the grill
Open and check for traces of dirt in the system due to insects. Clean the printed circuit board and check if the timer works. If not you will need to install a new one for using the timer. Hope the model uses the electronic type. If manual type try to clean and reset the clock action as a last resort.It might work with a good oiling, dirt cleaning using a good cleaner like WD40. hope you try this out. Good day
Aug 11, 2010 | Electrolux Ovens
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Self Clean does not work
heatman101
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
69 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
