Question about Alvarion BreezeCOM BreezeACCESS 2.4 Indoor Subscriber Unit Bridge/Router
Im using the old breezeaccess 2.4. I have RSSI of 60 to 65 but my link breaks badly.
  • 3,741 Answers
The ping settings are not getting set.reset the system and settings.get the settings configured.delete all the settings then reinsert all of them again and set it.then check out. -------- thanks.keep updated.
Posted on Sep 23, 2009
Bad earth on v reg clio
Dash light is probably a bulb, rear light will be bad earth.
Sep 24, 2017 | Renault Clio Cars & Trucks
What is the timing for a 1994 mercury tracer trio. i belive i have to replace the timing belt and the water pump. im not sure tho bc the feul cut off came on first than after i filled it up it went off. im...
First check to make sure the fuel shutoff is still on. When the engine jumps timing it is usually caused by either the water pump bearings went bad and seized or fell apart. The other is when the belt is old or excessively worn and breaks. Timing marks are dependent on engine size. 1.9 engines have single cam and all marks point straight up. 1.8 is more detailed depending on if it has 1 or 2 cams.
Oct 03, 2011 | 1994 Mercury Tracer
I cant hear from the earpiece, but im able to hear on the speaker. i think its a wiring problem, can i open and fix it myself? dont want to send it for repairs, have had bad experiences with phone repairs...
Plug it in and move the cable starting from the plug, making sure that you only move part of the wire. if it's a break, you might find the break and get the sound back while holding the wire in a certain way, which means that you'll have found where the break is. Depending on the location of the break in the wire, you may open the actual headphone and use a clip to hold the wire and resolder the wires (usually touch the end of the wire to the soldering gun and melt the shield coating away, dip in to flux and then to the mini board.)
If in the wire, carefully slice (lengthwise) into the wire (use any extra wire you might have to reconnect the old) then split electrical wire to seal the old wire. The Use the extra to secure the hold.
Thanks and have a nice day.
Jul 01, 2011 | Sony Ericsson W910i Cellular Phone
How do i reset password for Alvarion BreezeCOM BreezeACCESS 2.4 Indoor Subscriber Unit Bridge/Router
There is NO way of resetiing the device. You need to get hold of the factory reset device program from alvarion. This allows you to connect to the device and run a small program into which you enter the MAC address of the unit. The software then sets the unit back to factory defaults. You will need to run this program by connecting a cat 5 cable to each of the units you wish to reset and entering the MAC address listed on the device.
Cheers - Chris (Ex trainer of Alvarion Installation engineers)
Mar 15, 2011 | Alvarion BreezeCOM BreezeACCESS 2.4...
Can connect directly with laptop, but not via Linksys WRT54GX2
Many DSL modems need to be set into a 'bridged mode' when connected to a router. A call to Verizon customer tech support should be able to walk you through it as long as they supplied the modem. If not, and you do not have any documentation from your modem, go to the manufacturer's website and I am sure they will have a step by step. I hope that helps.
Sep 16, 2009 | Alvarion BreezeACCESS VL SU-A-5.8-6-1D...
Alvarion Password recovery
how to use wamp server software give me step by stp guience.plz help..........
Jul 09, 2009 | Alvarion BreezeNET AP-10 PRO.11
Vibration/shaking occurs when breaks are applied
(new roters, callapirs, breaks were installed), this truck is in a cross-over year...old style/new style,are the correct parts being used? if yes, I would check the suspension components under the front end along with hub bearings.
Apr 04, 2009 | 1999 Chevrolet Silverado 1500
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Point to point wireless problem
my link is wireless point to point on 5.8 ghz and is 13 kms apart it has RSSI level of -88 still disconnects
Apr 07, 2008 | Alvarion BreezeACCESS LB 5830
Alvarion BreezeCOM BreezeACCESS 2.4 Indoor Subscriber Unit Bridge/Router Logo
47 people viewed this question
Top Alvarion Computers & Internet Experts
randy yarpos
randy yarpos
Are you an Alvarion Computer and Internet Expert? Answer questions, earn points and help others
