Question about Kenmore 23022 Top Load Washer
Help!series 70...23701 (old machine)
How do I get the agitator off?? There is an article of clothing under the bottom, and I cant get it out..thus, the machine wont agitate!
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver
Posted on Apr 27, 2007
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
  • 481 Answers
SOURCE: Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
Posted on Jun 27, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
Agitator snappedin two at bottom? What would cause that? Is it possible to just re place the agitator?
agitator nut came loose
agitator plastic aged ..brittle
clothes got under and snap
a universal fit agitator
a used agitator from a washing machine mechanics stock of used parts
ebay ?
or if machine is not too old from the maker of the machine
Oct 30, 2016 | Washing Machines
Hello I have an older whirlpool and the bottom part of the agitator turns but the top part doesn't. Is it the clutch?
Take a flat blade screwdriver remove the hub on top, then remove the outer agitator cover and agitator then find out if an article of clothing is jamming the washer.themobilian_796.jpg
I found a kingsized pillowcase under the agitator jamming the works up.
Here is some more photos and a service manual
Jan 09, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My one year old son dropped a refrigerator magnet in our clothes and now the magnet is under the agitator. How can I remove this to retrieve the magnet and not stop up the drain?
Pull up on the fabric softener dispenser in the top of the agitator.
Set it aside.
Remove the agitator mounting screw from inside the agitator.
Pull up on the agitator base to remove the agitator.
Remove the magnet.
Reverse the above order to re-install the agitator.
Aug 09, 2010 | Maytag Legacy Series Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Removing agitator
Sometimes small articles of clothing can manage to get between the inner spin basket and outer wash tub. This is NOT common, however. If this were the case the memory stick you mentioned, would end up lodged in the drain pump. There would be a noticeable noise from the impeller hitting it and it may cause the pump to fail, resulting in drainage problems. More than likely, its right where you suspect it is. To remove the agitator, do the following:
1. Remove the center cap or dispenser from the agitator.
2. Under the cap or dispenser is another plastic cap with a pull handle on it. Lift this cap out by pulling straight up, exposing the agitator mounting bolt.
3. Loosen the agitator bolt using a socket and ratchet. Once removed, grasp the entire agitator assembly by the bottom flanges and lift straight up. The entire agitator should come out.
NOTE: When reinstalling the agitator make sure you DO NOT overtighten the mounting bolt or it can cause damage to the agitator and restrict the movement. Good and "snug" is the rule of thumb. has an excellent exploded view diagram of your agitator and components if you need a good reference. Just type in your COMPLETE model number and look under the "Agitator, Basket and Tub Parts" heading.
I hope you find what you're looking for and hope this helps you in some way. If you require additional assistance, please let me know.
Sep 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore 23022 Top Load Washer Logo
73 people viewed this question
Sal De
 Brian Main
Brian Main
