Question about Whirlpool Duet GHW9150P Front Load Washer
I also have the holes in the front of my shirts, around the belly
Last year I noticed that my thinnest cotton t-shirt suddenly develped a handful of tiny holes around the belly button. These holes were all concentrated in an area the size of a quarter. Today I noticed another shirt (slightly thicker cotton) has the same problem.
I'm ruling out the washing machine and insects, because if I did have this problem I think I would see holes in random places on my shirts, not just in the same area.
I'm skeptical about the wear and tear from the pants button, since the second shirt is loose and flowy. I also wear an apron when I wash dishes, so I really can't figure out what causes this. Unfortunately, now two of my favorite shirts are ruined. I wonder why it doesn't happen to my not-favorite shirts. Murphy's Law?
4 Suggested Answers
SOURCE: Tiny Holes in My Cotton Shirts
If you have granite counter tops then they are ausing it - There is either a small chip in an area where you lean across a lot or your edges are too sharp ( usually with a bevel this happens). I had the same problem for 8 years! Recently put masking tape all the around the edges of my counter tops to test this. No new holes. Just paid a guy to come and smooth down the edges all the way around - expensive but the savings in therapy bills will be worth it- I had been driving myself crazy tring to figure it out and slowly eliminated all other suggestions. I read where one women just started wearing an apron and that solved it for her but I spend too much time in the kitchen for that.
Try the tape - it is a cheap (though not attractive) test. I left it on for a month to be sure. Make sure to check bathroom counters, laundry room ,etc.
Ann
Posted on Dec 17, 2008
SOURCE: Tiny holes in the front of my t-shirts...
wow- my husband and kids were blaming me for putting holes in their shirts with bleach- tried to explain to them that i did nt use bleachon dk colors- will changing the tub help?
Posted on Aug 20, 2009
  • 82 Answers
SOURCE: i am finding tiny holes in the sleeves and fronts
Check for any small pieces of sharp metal in your washer tub on the front and back where the tub has a seam and is welded together. (you will need a flashlight and will have to put your head inside the washer to see this.) Check very carefully it could be very small. I have seen the stray metal welded into the tub and the tub would have to be replaced. Also check your dryer for anything sharp or holes in the front and back seals. Please rate this post.
Posted on Dec 14, 2009
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ann
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Holes in clothes
run a old hosiery or cotton wad (like from holloween) around the inside of the drum. see where it snags,
the drum is warranted for a very long time. (don't know exact)
Mar 26, 2008 | Kenmore Elite 45986 Front Load Washer
My machine makes pin size holes in thin t-shirts and not other clothes. It has ruined several new shirts-help!
It's a nasty twisty thing, my dear. It happens in just about every machine. The only thing you can do to be absolutely sure is to put those thin t-shirts in a pillow case, Strap it closed with one of those "what's those hand-cuffy things called" things? and pray you don't get small pin-sized holes in your pillow case.
Mar 04, 2008 | Washing Machines
Circles on my laundry
first lets figure out if its coming from, do you notice them before drying??? solid circle or a ring? streaks would be more a common complaint, but a complete circle?? does it come off in next cleaning ??
Feb 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help - my clothes are tearing
I've heard of this often and don't know of any fixes.
I would suggest getting womens hosiery or Halloween spider web cotton and running it around inside to see if it snags.
make sure the basket arms inside are not loose. rock them hard while holding the drum. sometime those arms come loose and pinch the clothing.
Feb 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
