Question about Car Audio & Video
Wireing i have a kraco power booster but don't know what all the wires are for. is there a diagram for hooking them up
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
SOURCE: I dont know where to hook up immobileizer bypass wire
An immobilizer bypass is an electrical circuit which allows current to flow to whatever component is starved of current to keep the engine from running (usually the coil). The immobilizer opens the circuit to the coil, the immobilizer bypass closes the circuit to the coil.
If you didn't install an immobilizer circuit, then you don't need the bypass. There are probably instructions you missed in the manual explaining the immobilizer circuit.
Posted on Apr 30, 2009
etirbynnor
  • 655 Answers
SOURCE: 1998 Toyota Camry Le Wiring Diagram. i want to
Hello motoxbear17,
You do not specify what particular amp or powered subwoofer you intend to install, so I'm assuming that you have an amp that uses a remote 12V+ signal to turn the amp on and off. Some powered subwoofer systems like the Bazookas, Infinity Basslink, and MTX Thunderlink use an "audio sensing" circuit that turns the sub on only when the radio is on. Some amps also have such a "turn-on" circuit that is active when speaker level inputs are used. I'd recommend that you check the documentation that came with your amp and see if it has such a feature.
For a normal subwoofer amp with power, ground, and remote terminals, the remote terminal usually just needs a 12V+ source to turn the amp on.
In your vehicle, the gray wire coming from the receiver harness is a 12V+ switched source.
Here's a link to the '98 Camry wiring color code:
http://www.modifiedlife.com/car-stereo-radio-wiring-diagram-1998-toyota-camry/
With this connection, the amp will power on whenever the vehicle ignition is on or in accessory, regardless of whether the radio is on or off. If this is objectionable, you can simply add a SPST toggle switch inline with the lead and turn it on only when needed.
Hope this helps.
Posted on Oct 19, 2009
  • 3197 Answers
SOURCE: wiring is hooked up wrong, need to know the wiring
White wire with red tracer goes to terminal 1, Three solid white wires go to terminal 2 and the two white wires with black tracers go to terminal 3.
Posted on Dec 24, 2009
  • 239 Answers
SOURCE: I have a Clarion M 475 radio that came in a used
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
this is the standard wiring for clarion cd players
Posted on Aug 16, 2010
Why does my CB only have black and red wires what are they to?
The red wire is your positive wire and the black wire is the negative wire. This hooks up to a car battery or a power supply to turn the radio on.
Sep 06, 2014 | Green Planet Kraco Kp6001h Replacement...
I need a wiring diagram to get the color codes for a realistic 40 watt equalizer booster model 12-1954
All the wires on my 40watt realistic eq are all the same thickness and I have three red wires can someone tell me what side the power wire should be on and which color wires would go for speakers and which color go for the amplifier
May 09, 2012 | Car Audio & Video
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
Now power to the trailor hook up on back bumper, fuses are O.k. wiring apears to be o.k. it is dodge ram 1500 4x 4 single cab c/w 4.7 8cly. be nice to get a wiring diagram. thanks Wayne
you will need to check the wiring under the bumper where the trailer wiring is with a test light and with the different lights working.you will probably have to move back in the wiring by 6" and retest until you find were the loss of power is.you don`t say if all the lights don`t work or just certain ones.the brown wire is the tail light,green is the right signal light,yellow is the left signal light and white is the ground wire.you could have broken wires at the trailer hook up itself.
Mar 22, 2011 | Dodge Ram 1500 Cars & Trucks
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
STEREO WIRE CODES DIAGRAM FO A 1998 BUICK CENTURY
need codes to hook up radio to 1999 buick century
Aug 22, 2008 | 1998 Buick Century
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
May 21, 2008 | Car Audio & Video
Outside fan motor with relay and two capacitors, one capicitor has three prongs and the other has two. need wiring diagram to help ensure hook up is right and also need to know how to test relay and caps...
are you looking to wire up the fan or rewire the whole outdoor unit? The fan capacitor is the one with two prongs and you should have two brown wires coming off the fan. One brown wire per terminal
Apr 18, 2008 | House Brand Heating&Air Conditioning...
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
