Question about Cell Phones
Nokia 6500 slide signal problem
Hi, I dropped my Nokia 6500 slide in the toilet! after a few days of leaving it to dry out it now works fine. The only problem is the signal keeps dropping and sometimes i get no signal at all, seems worse when battery level drops. I have had the battery tested and all is fine with that. Any ideas?
My nokia 6500 slide two days now no more displaying any thing and no more switch on again. please send me solution.
did ur handset fell in water or u are in a cold region.... ?! if it is so then switch off ur mobile, remove the battery and dry it in a hot place also dry ur mobile....
Dec 08, 2010 | Nokia 6500 Slide Cellular Phone
How to open nokia 6500 slide now
Hi jenykin,
It is quite hard to push the slide upwards, just thrust it slowly and move it upwards so that the slide will get opened,,,,
Please leave me comment, if you need further assistance
good luck with your fix,,,
have a nice day,,
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Mar 10, 2010 | Nokia 6300 Cellular Phone
Dark screen after being dropped in water
try drying it with a throughout hairdryer ie take the battery out and give it a blast for maybe5 minutes then try again.
Mar 09, 2010 | Nokia 6500 Slide Cellular Phone
Nokia 6500 Slide. Wired headset - no sound.
brother i have also the same problem what i can do?
please help me
Nov 10, 2009 | Nokia 6500 Slide Cellular Phone
Hi, the speaker on my nokia 6500 slide, sounds awful
yea you should change your speaker
when you change it get a nokia original speaker
not an after market one cauz they dont work as good
Oct 13, 2009 | Nokia 6500 Slide Cellular Phone
Hi my nokia slide recently lost signal altogether and ive had to get another phone any idea wots wrong with it and how to fix it
try going to settings then find master reset,then fone will restart and should restore everything to factory original and most of the time that helps instantly.if my info was of any help please leave a comment,note,vote.thankyou
Sep 10, 2009 | Nokia 6500 Slide Cellular Phone
Hi there..i have a signal problem with my nokia 6500
Try checking with your service provider if there's any outage problem in your area. Which is possible since you don't have any bars for signal on your phone.
Sep 05, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
I dropped it down the toilet now it just wont work.
There is a possibility of it working again but water damage does alot of damaging things to phones. The best solution is to take the battery out and don't use it or try to charge it for a few days. Let it completely dry out and it might work but chances are slim. No matter what you hear or read do not place it in the oven, dry it with a hair dryer or even place it in rice. Those things will actually cause more damage to your phone.
Jan 27, 2009 | Nokia N95 Cellular Phone
Cell Phones Logo
188 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
