Question about Dryers
My dryer has stopped blowing hot. not heat at all. and i noticed that the back vent was all clogged up. its electric.
    President:
  • 1,776 Answers
I would suspect that the clogged venting caused an overheating situation and possibly blew the thermal fuse. It is usually inside the rear of the dryer attached to or near the exhaust duct. It's about one inch long. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad thermal fuse. The heating element can be checked in the same manner. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 23, 2009
My maytag dryer has plenty of heat and the drum is turning, but it is not blowing the hot air and moisture out the vent. I have checked the panel box and everything is fine. My dryer is a Maytag Bravos,...
pull the vent hose off the back of the unit turn it on and make sure it has alot of blowing power if it does blow good you have a clog in your vent hose somewhere,, if not your blower could be bad,, if i remember correcly that one has a belt just for the blower also check that
May 03, 2011 | Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your cloths are "hot and damp" you are not getting proper ventilation. Since you cleaned the vent trap let's try a few things to narrow down where this vent restriction is coming from.
  1. Let's pull that vent trap up and start the dryer. Place your hand a few inches in there. Can you feel a light suction of air? (flowing into the dryer)? We will get back to this shortly. Next -
  2. Take the vent hose off the back and turn the dryer on? At this time you should get lots of warm air blowing. If you do not have this and the vent trap did not have any noticeable air flow (into the dryer) then thus far you have a clog between the vent trap and the vent in the back of the dryer. Unplug the dryer and from the rear of the dryer remove the back panel. Should be just a few 5/16 nut with a possible flathead screwdriver indention on them. If you have to do this let's still check the pathway for ventilation to the outside and make sure one did not trigger the other. And if all ventilation to this point is good then -
  3. You have a clogged vent restriction between the duck and the path it takes to outside. For this a duct cleaning service will have to come out and take a high pressured air hose and blow that pathway clear. Now if you have a fairly high powered compressor and can locate the exit for the dryer vent then -
  4. Charge that compressor and put an air gun adapter on it and (wearing eye protection) blow the heck out of it. This will make a huge mess no matter who does it. Make sure it is a good size shop compressor and not one many people carry in their trunk for inflating flat tires (this one will not work) This is how the duct service will do it also.
Mar 20, 2011 | Dryers
The timer will not advance, it heats up on the correct settings, but will just stay on indefinately. Sounds like a classic Timer issue, but just want to ask for a second opinion, and ask what the part...
We have a dryer ( could be any make! ) that is consistently blowing fuses after about 15-20 minutes. We have taken the dryer apart to check for clogs in the venting system and to check if the heating core was okay and they seem to be fine. Any ideas?
Blowing the house fuses? If yes....the dryer usually will blow a fuse right away if there is a problem in the dryer....more often than not a fuse that blows after the dryer has been running a while it is a fuse box issue. A test: Put 2 new 30 amp fuses in and run the dryer with the heat on for 5-10 minutes, turn off the dryer and quickly remove the fuses from the house fuse box and see if they are hot at all ( especially on the bottom )....if the fuses are getting hot they are probably melting the fuse link and not really blowing = fuse box problem.
As for most things there are exceptions....a grounded heating element -may- blow the fuse after the dryer has been on for a while, it is easy to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a problem.
Dryer basics- Venting problems and power supply:
Most dryer "to long to dry" or "poor/low heat" complaints can be traced back to a bad or poor venting system and sometimes a poorly maintained lint filter. Do not go outside and put your hand under the vent opening and say " it is fine - I feel air coming out"...that is not good enough...take your venting apart, clean it ALL out and make sure the vent hood flapper works and that it is not clogged with lint. Make sure your venting system is short, straight and resistance free as possible. A poor venting system will shorten the life of your dryer, plug up the fan blower and duct work inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer. Electric dryers need 240 volts to operate the heating element and 120 volts to operate the timer and motor. You should see 240 volts between the black and red wires, 120 volts between the red and white wires, 120 volts between the black and white wires at the electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still allow the electric dryer to run but you would get no heat. Depending on which fuse goes, sometimes the dryer could be dead as well. If you have problems with a fuse letting go or a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
Dec 16, 2010 | Dryers
Our dryer is a model # fer641fso. it is notgetting the clothes dry without running 2 or tree cycles. the dryer is very hot to the touch in the back and very warm on top. the vent is hooked up properly. any...
u have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Feb 03, 2010 | Frigidaire FER641FS Electric Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer gets really hot, blows circuit breaker, vent is clean and clear, circuit breaker replaced, seems to be something that controls the heat isnt working..
Howdy: In back of the dryer is a thermostat (inside) that lint hangs to. If it reads too hot it should stop heating. If not working then blows breaker. Inspect please, we do not want a electric fire. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
No heat from GE electric Dryer
Possible. Here are all of the reasons why you might not be getting heat. Read them over and get back.
Jun 07, 2009 | Dryers
Electric dryer not blowing hot air
Sounds like the heating element is not working, make sure you are getting 220 volts to the recptical. Let us know if that did the trick. If not let us know thankyou
Mar 15, 2009 | Dryers
Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Feb 10, 2009 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Dryers Experts
