My vostro 1760 laptop shows power but a black screen Also I cannot switch it off I can hear it running but nothing I do will switch if off I was working on it & didnt realise the battery was at a critical level so it just turned off I plugged in the charger & left it The screen came back up sometime later to say Windows resuming then a few minutes later it went black again This was hours ago the power light is on & I cannot switch it off Why? The battery would have charged by now Please help!
  • elainemullet Sep 23, 2009
    I am so tired i meant to type vostro 1720 Thanx
    Novelist:
  • 225 Answers
How do you switch off you laptop? Try this press and hold on the power button for about 5 seconds. So it won't boot to windows? When you turn on the laptop and you see the dell logo keep tapping on F8 then try booting in safe mode, if fails do F8 again then last known good configuration, if fails do F8 then startup repair, if fails do F8 then system restore, if all fails reinstall os. but before all these steps try to test hdd first. make sure laptop is off. press and hold on the Fn key then press power button. Run the PSA test and once it finish it will show you some errors code like 0142 -0146 means hdd needs to be replaced.
Posted on Oct 04, 2009
The button is on and the lock 9 is on and flashing and the screen is black. It was working fine. I opened the laptop and my screen is black. The A in the lock is blue and the icon next to it. The power...
Hold the power button for 5 seconds or more - does it turn off properly? If so, can you turn it back on afterwards?
Take out the battery and unplug the power adaptor. Let it sit for a few minutes. Now try the power adaptor alone. If this works, try shutting down and running on battery again.
Apr 18, 2010 | Dell Vostro 1510 Laptop
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1000 won't turn on/no power at all
My problem was similar!
I would press the on button, little power light came on, could hear 2 sort'a clicks (like it was trying to start up), then nothing.... A black screen. Power showing on; but just not booting up.
I have read quite a few people out there having the same problem, with few solutions. And like them, I tried all the usual methods plus a few "let's see if THIS makes it work" methods!
Now let me state something important here: My computer DID boot up after turning the system (read; pressing the power button every 10-15 seconds like a trained chicken) on and off between "10 and 30+" tries!!
So.....that told me, in lay-man's terms, my puter was just act'n plain goofy!
Telling myself I can't go through this test of patience EVERYtime I want to use this thing, I stumbled on a cure for my problem!!
What I did was; unplugged the power, let the battery run down (to the point where my laptop quit on its own) [btw, you should be sure to only have the desktop showing and not have any applications running to minimize problems!]
I then plugged it in, and turned it on. To my amazement, it booted on the first try!
If you have tried all the normal methods of fixing your computer and it still will not work right; you might want to give this a try as a near-to-last resort!
I sincerely hope this works for any one out there who is having this problem when it takes multiple attempts to get your system to boot!
This occurred on a Vostro 1000, running Vista (home edition)
HAVE A GREAT DAY
Rod G
Mar 23, 2009 | Dell Vostro 1700 Notebook
Computer turns on but nothing happens
your monitor should have nothing to do with the internet
Are your internet lights on
Have you moved the system maybe causing something to become loose.
Is the monitor plugged into the wall correctly and into pc correctly
can ypou hear windows starting up or does everything just go black
Dec 15, 2008 | Dell Vostro 1500 Notebook
Mintek MDP-1760
My Mintek MDP-1760 try to loading the dik and later show a mesage NO DISC... what is the proble?
Jan 30, 2008 | Mintek MDP-1760 Portable DVD Player
DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Aug 21, 2007 | Mintek MDP-1760 Portable DVD Player
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
