Question about Christie Office Equipment & Supplies
Invalid lamp ballast id on 16k Christie This happens when the projector is powered up and the on button pushed. The lamp will strike after many tries ie dropping power and re powering once running no worries.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Posted on Jul 21, 2015
SOURCE: PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Posted on Jun 06, 2009
projdoc
  • 2237 Answers
SOURCE: SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Posted on Aug 03, 2009
projdoc
  • 2237 Answers
SOURCE: Ballast issue on LP640
first off, many churches and schools hang their projectors from the ceiling, and the only time they take them down is when they don't work. it sounds rational, but it gets dusty up there, and without proper and relatively frequent cleaning, the dust builds up and the projector can't release the heat properly. this causes a lot of malfunctions. the ballast is only one of them.
to replace the ballast:
make sure you can get the part from infocus or an authorized service center. it's part # 525-0085-51. after you remove the cover (4 screws on the bottom. you'll need a T10 torx driver. slowly slide the top forward and lift off), gently remove the ribbon cable by sliding the cable locks (on both sides of the cable) towards the front and pulling the cable out. the ballast is at the front of the projector next to the lens and in front of the lamp. pull it out and remove the ballast from it's housing. there are 3 cables coming off- the power plug, the lamp plug, and the lamp enable plug. remove those and replace the ballast. reverse the steps to install.
Posted on Aug 15, 2009
  • 23 Answers
SOURCE: LP540 Projector Lamp Does Not come on> it has
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Posted on Jan 20, 2010
  • 23 Answers
SOURCE: I have the Sharp XV-z90u and we just replaced the
Or you could test it with just a burner which would be even cheaper. LumenArc sell burners individually. Your problem could be a ballast as well.
Posted on Jan 21, 2010
I have a Christie LX20 that I just replaced the lamp and plug the power core back in but no power after lamp replacement
The old lamp might still be good. The ballast board in the projector controls when the lamp goes on and off. That board may be faulty. The bulb socket wires connect directly to this board.
Mar 29, 2017 | Christie Office Equipment & Supplies
Christie LX32 Lamp
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Mar 09, 2014 | Christie LX32 Lamp
Christie Roadster 16k is about ready for a lamp replacement. Should the air filter be changed at the same time? If so, what's the Christie product number of the filter?
yes. it is recomended to replace the filters whenever the lamp is replaced. if you have a 500w lamp, use filter #003-120118-01; 1000w lamp, filter #003-120117-01; 1200w lamp, filter #003-120116-01.
Oct 01, 2009 | Christie Roadster S+16K DLP Projector
Toshiba MT8U projector strikes lamp then goes out
it's the ballast or power supply. the lamp gets about 250vdc until it reaches a certain point, then it drops to about 20vdc, but the high strike runs through a different part of the ballast than the maintenance voltage.
Jul 07, 2009 | Toshiba TLP 680 Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Christie Roadrunner 100
check to see if the fans are moving. if not, replace the fans. if the fans don't come up, the projector shuts down to protect the circuitry and the lamp. if the fans are fine, most likely the power supply/ballast is not producing enough power to keep the lamp lit and shuts down.
Aug 14, 2008 | Christie LX45 Multimedia Projector
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
116 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
