Question about IBM ThinkPad R40 2681
I installes a phillips wireless card but need the
I installed a phillips wireless card but need the driver for it to work
  • Donovan Merrill
    Donovan Merrill May 11, 2010
    What's the model number?
  • 177 Answers
Go to google, type in the model # followed by the word drivers. It's that easy. Or going to the Phillips site directly will possibly help, but it's actually going to be faster the first way
Posted on Sep 26, 2009
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
I have a problem... Afer installling my Operating System my 3D won;t start running.. What could have caused this??? help!!! Need it a lot
Your 3d card driver's might not be compatible with the operating system you installed so download the specific drivers to fix the problem
May 15, 2010 | Computers & Internet
I have windows vista and a dell inspiron 530 and I have ATT wireless using a little 2 wire adapter I am constantly loosing my connection so I have to unplug, turn off computer anything to try to get a...
have you try to update the network card driver on your computer. if you haven't try that first.
here's the website for your unit, please find update driver's for your OS and make sure you installe the component, install the driver (follow the instructions) and the reattached the component again, hopefully it will work this time: you unit driver page
Dec 26, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Cant get wireless to work
if u knew how to open wireles card, then open it and clean wifi card using Pencil Rubber, then fix it back if still cant, rool back driver, if cant reinstall driver . if cant remove and Installl a new driver, then its should be ok
Oct 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Wireless button
The T30 laptops do not have a on/off button that turns the wireless card on.
Once the wireless card driver is installed the wireless card will detect any wireless router and access point within its range. You need to configure the wireless card to connect into the wireless router or access point eg. the encryption, SSID etc.
The Thinkpad laptops have different wireless LAN cards installed, when you install a wireless card driver and it doesn't work, then install a different model wireless card driver. Also make sure the XP or Vista version of the wireless driver matches the Windows version that is installed on the laptop.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
No sound card installed Xp automatically
you need to find what kind of soundcard you have and download then install the drivers for that sound card, open up the case if you have to and try to read what brand the card is and what model it is, then go online and get the drivers, that should fix your problem
Jun 15, 2009 | AudioBahn ALD28X 2-Channel High...
Cannot connect the internet
Linksys has the drivers for your device.
Goto:
http://www.linksysbycisco.com/US/en/support/WMP54GS/download
You should have no issues using the driver directly from LinkSys web-site.
Also, just to make sure, open your case and re-seat the card, before installing the drivers.
Let us know.
Good luck.
Apr 14, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
IBM R51e Thinkpad Wireless problem
hi liza,
welcome to fixya,what u can try is that installe dth utility for the wireless card and turn on the wireless zero configuration from the windows and then try and connect with the windows and also with the utility,or what u can also try is that go to the router page and then configure the wireless lan,as alike 802.11 b/g channel and then try and connect if it still doesnt connect then resintall the operating system and then try and connect it should work.....good luck......pls rate this solution for me pls.....
thanks
Feb 14, 2009 | Lenovo ThinkPad R51
Installed XP SP3. audio not working
I need driver sound card for PCI\VEN_13F6&DEV_0111&SUBSYS_80E21043&REV_10
Oct 05, 2008 | ASUS M2N-MX Motherboard
IBM ThinkPad R40 2681 Logo
63 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
