Question about Hotpoint Aquarius WF220 Front Load Washer
I need to remove the bearings from the drum of my washing machine how do i do it
  • 909 Answers
Its not impossible but a real battle without the correct tools. If at the back of your washer, you have the main arm assembly, then firstly remove the belt and then the pulley.Undo the nuts holding the assembly and in short, pull that assembly off by pulling it towards yourself. Once off, you will see the bearings and seal that need to be replaced. Once done, reassemble carefully and god luck.
Posted on Sep 23, 2009
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
HOW DO I REMOVE WASH DRUM
Removing the wash drum is generally one of the bigger washing machine jobs requiring a major stripdown.
When the casing and the front of the tub have been removed the drive pulley is removed and then the drum and spider assembly is pulled from the bearing.
In reality it is usually something needing a big hammer or giant mallet and hitting the shaft like a madman until eventually the bearing breaks up and releases the drum and spider.
Feb 26, 2015 | Washing Machines
Bearing replacement
One of the biggest jobs to do on a washing machine. Remove the drum from the machine, remove the washer drum, knock out bearings, replace drum spider (shaft) fit the new bearings, and drum seal, put everything back together again. Job for a experienced engineer.
Oct 03, 2014 | Washing Machines
Samsung front loader washing machine
Sounds very much like the drum bearings have failed. It is not a DIY job I'm afraid. Up to date washing machines are now impossible to actually replace bearings and only way to repair is to replace inner and outer drum assembly. This is a 1/2 a day job at the least to a professional. Older machines.....you can replace the bearings but this still involves removing the outer drum ou from under the washing machine, and the a very normal bearing removal and replacement procedure. Make sure the bearings are knocked in very straight and not on the skew. Good luck
Nov 24, 2013 | Washing Machines
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Noisy bearing on drum
This is not an easy job on any washing machine. The AEG is probably the same as most washing machines in that it has two bearings on the shaft at the rear of the drum but it also has a carbon water seal on the inside and usually you will need to change this too as if you disturb the bearings it will surely leak. If you have never done this before it can be dreadfull. If your drum has bolts and a seal at the back to withdraw the inner drum and back plate out the back of the machine then you are lucky and you should be able to do the job in about two hours. If you dont have a removeable back on the drum you will have to strip the whole machine and remove the drum supports and hydraulic pistons at the bottom. All hoses and pipes and wiring attached to devices on the drum will have to come out as well as the door seal and soap dish rubber connector. Good luck.
Apr 03, 2009 | LG Washing Machines
How easy is it to change the drum bearings on my indesit wil163s?
you will need to remove the pulley first, the screw in the middle will need a knock to release the loctite.
you will then need to remove the spider assembly, that's the metal cross the bearings are sitting in. there are bolts set around the drum. spray the bearings shaft with oil to help removal, and you may need to hammer the spider as you remove it to loosen it. be careful of the heater.
then knock the bearings and seal out and do the reverse proceedure to put back together.
Feb 27, 2009 | Indesit W 123 Front Load Washer
How do you change bearings on a indescit wil133 washing machines
You will have to remove the rear panel and drum pulley to access the drum . shaft and bearing housing.
Then depending on the set up, you will have remove whatever screws there are to remove the bearing housing.
Dec 06, 2008 | Washing Machines
Hotpoint Aquarius WF220 Front Load Washer Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
