Question about John Deere 48 in. EZ Trak Power Flow Assembly
HAVE A Z TRAK 717. ENGINE QUITS AFTER 20 MINUTES. SOUNDS LIKE ITS RUNNING OUT OF GAS. PLUGS,AIR FILTER OIL,FUEL FILTER GAS LINES ALL O.K.
  • 496 Answers
Just a thought for your consideration...
If you can, check the carburator to see if you have condensation trapped in the bowl.
Hope this helps... Good luck!
Posted on Sep 23, 2009
Spec vin ecu specs
If it turns, then the battery is OK. Either spark plugs are not firing in proper order (wrong firing order), no power to spark plugs, or no fuel because of fuel restrictions (dirty fuel filter). Inspect the air filter to ascertain its not clogged air. If you smell gas, then you saturated the spark plugs, which is why it refuses to run.
Let it sit for half hour to let spark plugs dry. Inspect to ascertain its not dirty spark plugs, which will also prevent engine from running. After ascertaining its proper firing order, spark plugs are clean, and there's power to distributor cap, ascertain there's fuel in fuel lines by squirting half second (short squirt) of starting fluid into air filter. Close the air filter housing to trap flammable starting fluid gas. Turn engine without giving throttle. Let starting fluid be ignited by spark plugs. If it won't start, then spark plugs are not firing to ignite starting fluid gas. If it starts briefly, but won't run when you give throttle, but catches when a 2nd person squirts more starting fluid into air filter just before engine stalls, then its a fuel restriction issue or no fuel in fuel lines.
Nov 29, 2013 | Cars & Trucks
'01 Toro Zmaster...cuts off after running 20-30 minutes. will start right back up but will cut off again. After letting cool off I can mow again. changed spark plugs, cleaned air filter
Hi
When your leaf blower quits after it gets hot, you either have a problem with gas flow being restricted into the engine or with the spark. This is a common occurrence on older-model leafblowers. By replacing your spark plugs and keeping your gas lines clear you can reduce the chances of this problem recurring.
Possible Vapor Lock:
Vapor lock happens when excessive heat and vapors build up in the gas tank and aren't vented properly. Check for this problem the next time your saw dies when it's hot. Unscrew the gas cap, vent the gasses and try to restart your blower. If it starts you have vapor lock, and will need to carefully inspect the fuel tank's vent hole to see if it is plugged or damaged. Clean this hole with a brush and rag.
Possible Ignition Problems:
A common problem is an old or dirty spark plug. When the plug gets covered in black carbon the spark will have difficulty firing, especially when hot. You may also have a problem in the ignition module or the coil in the module. Again, run the blower until it quits and then squirt a little starter fluid into the open choke valve, underneath the air filter. If it starts up you likely have a fuel system problem, but if it doesn't start, your ignition module or coil is likely almost finished.
Fuel Supply:
At certain times when the engine gets hot, the flow of fuel to the carburetor can get restricted. This can occur with a dirty fuel filter on the end of your main hose. The hose itself, when hot, can also lose its proper seal to the carburetor, restricting the flow. Replace your fuel filter and hoses on a regular basis, usually once a season. Try adjusting your carburetor's screws to see if you can richen the fuel mixture in the carburetor.
Other Problems:
A dirty or worn-out carburetor can also cause similar problems when hot. You should get your carburetor cleaned and serviced. Try installing a carb kit to older carburetors to help with the flow of fuel. A fuel pump inside the carburetor can also start failing and any warping in the diaphragms will also cause similar problems. You can check for a dirty carburetor by squirting a shot of carb cleaner into the open choke hole just after starting the engine. If you see a lot of thick, dark smoke pouring out the muffler, your carburetor is dirty.
Please take time to rate me
Bud
Apr 21, 2013 | Garden
I have an L120 lawn tractor with a B&S 22hp v engine that will not start. I have changed the spark plugs, gas filter, both air filters. It cranks / turns over very strong but does not start. It...
Sounds like gummy gas. Try a shot of carburetor cleaner down the fuel line to the carburetor. Or take the carburetor apart and clean it, squirting through all the tiny holes and inspecting the float needle for abnormal wear. replace the float needle assembly if necessary.
Oct 17, 2011 | John Deere 420,1020,2010,2020,2510,2520...
When my Altima has been running a while (on frwy) At about 60 -65 MPH The car feels like it jumps. Or wants to switch gears. Then when i come to a stop, such as a red light The car sounds and feels as if...
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Aug 17, 2011 | 2003 Nissan Altima
RUNS 2 MINUTES QUITS WHAT A PAIN ED
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is tightly fastened to the engine. Will it start and run another two minutes just after it quits? Try loosening the fuel cap to see if that affects the running time. When it quits, remove the spark plug to check for spark. If nothing, the ignition module may be failing. If it appears to be loss of fuel when it quits, the carburetor may not be pumping fresh fuel into itself--remove the carburetor and check the impulse passage that runs from the engine to the rear of the carburetor for leaks of any kind. Hope some this helps!
Dec 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Not getting gas to the carb. can blow air on the gas line back to tank, as soon as the motor starts the line becomes empty engine quits
Check the fuel filter, air cleaner, and muffler for plugging. Check all fuel lines for decay or other problems. Make sure to have fresh fuel/oil mix in the tank. Be sure to premix the fuel and oil in it's own container and shake the container thoroughly just before adding to the tank each time to prevent oil starvation. Don't make up more than a gallon at a time unless sawing is your business. Hope this helps!
Nov 05, 2010 | Garden
Battery was dead, charged; engine will turn over, but not crank. Spark plugs ok, fuel filter ok, fuel pump ok. When I try cranking, strong gas smell. Mower has 30 hours on it, one and a half years old.
Try taking gas line off pump that goes into carb. Crank it, if gas won't come out, tap on fuel pump. If gas still won't come out after tap it with a wrench. Either replace fuel pump or check gas lines making they are free.
Feb 21, 2010 | John Deere 42 in. EZ Trak Bagger
Reduced engine power
New fuel filter, Spark Plugs & Wires, New air filter.
Tires at max cold psi.
Use a bottle of injector cleaner and change oil every 3k
Aug 19, 2009 | 2002 GMC Envoy
John Deere 48 in. EZ Trak Power Flow Assembly  Logo
224 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
