Question about Compaq Evo N610C Notebook
Fan Cleaning I hear the cleaning the fan can be an effective way of fixing overheating problems, but I can't seem to find any place on the internet that gives instructions... I'm comfortable taking the laptop apart, but would like an idea of what I need to do before doing so... Thanks!
  • 383 Answers
The Link Below is the answer to Cleaning lap tops :
How do I clean my laptop?
To help prevent this issue, place something in-between the fan blades, ... Cleaning the inside of a laptop computer can be a difficult task.
Good Luck, Please dont for get to Vote, Thank You.
Posted on Dec 15, 2007
How do you stop a laptop from shutting down?
When the overheating issue is fixed, the laptop will reset. Did you clean the radiator? Is the fan running?
Oct 09, 2014 | Computers & Internet
yes clean your fan out,or check the heat paste on your processer.
what i do is get a hoover and put it next to the fan and try cleaning it that way,if that dont work you might endup opening your laptop to clean it.
Apr 12, 2014 | Acer Aspire AS15515448 116Inch Notebook...
The above as over heated and seems to fail after about ten minutes of being on this is an intergrated card can it be fixed without replacing the motherboard it is in an asus laptop.
I suspect that your cooling fan has stopped working or the sealing mating between the fan surface and the CPU is not intact. These fans quit working because dirt and grime gets into the fan shaft and friction slows the fan . also if the fan gets accidentaly moved on the CPU, then this breaks the heat transfer tape between the CPU. This over heating causes the CPU to fail. Open the machine and observe if the fan is running correctly.
Apr 14, 2011 | Computers & Internet
My Dell 610D runs for about 15 minutes getting progressively hotter(speed fan) and then just stops working?
It sounds like the DELL is overheating and shutting down and if it cannot start up again straight away until it has cooled down then it is definitely a thermal overload (overheating) problem.
If the fan is OK then the fault is most likely dust clogging the fan and heatsink assembly.
The fix - loosen the dust from the vents, fan and heatsink assembly and vacuum/remove the dust off these components.
Use the laptop on a flat hard surface and/or place small pads to increase the height and ventillation to the laptop.
If the problem persists then there are products such as fan assisted cooling pads that you place the laptop on to provide addition cooling to the laptop,
If you continue to ignore this problem then eventually the CPU chip will fail.
Dec 24, 2009 | Dell Latitude D600 Notebook
Assuming that your fans are spinning, and it is just a matter of turning your laptop over while it is running and see if you can see the fans or feel the air flow.
However, if your system has never been cleaned, I would perform a cleaning.
This is what a laptop may look like, from the inside no air can flow.
A normal cleanup may not blow out the dust, so an internal cleaning is best.
These are what clean heat sinks are supposed to look like.
Good luck
God Bless
Jun 28, 2009 | Acer Aspire 4315 Notebook
Iomega media drive cooling fan
You can try cleaning and oiling (light oil, like 3 in one)the bearings on the fan but it usualy doesn't work. YOu can obtain replacment fans from : Match diameter of fan .You can measure it withb a ruler. and ever other computer parts place.
Jan 12, 2009 | Iomega (32691) Case Cooling Fan
My notebook is overheating
you need to buy a notebook cooling pad, if you don't have one on your laptop. this can help to reduce overheating of the laptop..
click HERE to see.
Jun 26, 2008 | Compaq Presario M2000 Notebook
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
I would buy a can of compressed air and see if cleaning out some dust will get the fan blowing the way it should. It definitely sounds like it is overheating and cleaning out the dust may be the most cost effective way to start. Let me know how you make out.
May 28, 2008 | Dell Inspiron E1505 Notebook
Compaq Evo N610C Notebook Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
