Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red Lines across the whole screen
I can't seem to get rid of the red lines streaking across the whole screen on our 51 inch Magnavox HDtv....can anyone help before I shell out a fortune to fix it???
    President:
  • Philips Master
  • 1,779 Answers
It most likely needs the Light Engine, but I would seriously consider not investing big dollars in a DLP set. Reason: 9 out of 10 manufacturers have quit production months ago and some 2 yrs ago due to high failure rates and newer technology.
Posted on Sep 23, 2009
  • Jim Krause Sep 24, 2009
    Rulds2008>>>>> DLP sets do not have convergence boards. Please do your homework before helping. I'm not trying to hurt your feelings, however, see you have never repaired a DLP set.
  • Philips Master
  • 3,866 Answers
This would consitute a covergence board issue and would need to be looked at by a qualified Tv repair technition prefer a Autherized repair technition at that such as myself. You can try if you have the expertise to repair this yourself but you need the tools to do it. Also what most people do not know and what the factory does not tell you there is a service menu you can load on this to run the convergence in Auto to try to correct this. The only bad thing about tell you that there is this menu is I cannot give up the instructions because you could make your situation worse and then come back and pass liability. So in saying that I do think your should seek a professional it might cost you areound $89-$150 to fix but well worth it because its done with qaulity. Thanks
Testimonial: "Thank you very much...it seems like everyone is having this same issue with their TV's too...I will have to call someone to fix it then..."
  • Grand Canyon Tech
    Grand Canyon Tech Sep 23, 2009
    Good luck with that sir and thanks for the beautiful commens and ratings sure does help me stay on the top!! :)
How do I get rid of diagonal lines across my Mag. HDTV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 06, 2014 | Magnavox 19MD359B F7 19 in. HDTV
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have a KP-51ws520 that a friend gave up on and bought a new LCD TV. About a year ago, after a power outage in our neighborhood, this tv now has noticeable streaks across the screen at all times. Is...
It depends on what the problem actually is; are the streaks colors like red or blue outlines around lettering etc?
The more you tell me the better I can help. I will post a photo or two of what convergence problems look like.
This set is also prone to another problem, on a blank video input look at the screen: you should only see Video 1 (etc) and if you see faint curved lines (red, green or blue) and or the back ground is also wrong color you have the second problem.
let me know which it is.. If this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 20, 2010 | Sony KP-51WS520 51" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Magnavox 51" Rear Project Red Streaks
Sounds like the convergence IC's went south.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Hitachi 51S500
check out ctechnicians.com and ask if its the pink screen?
Dec 25, 2007 | Hitachi 51S500 51" Rear Projection...
Red and green lines across the screen
classy cuban,
Probable convergence issue....replace convergence IC's
Guest,
In front of set behind access panel,locate RGB focus and screen
adjust block.....turn red screen control ccw a bit........
m888, Your monitor has a bad CRT.........................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
192 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
